Thread: vBulletin 4.0.4 'postfoot' class issue
    Apr 2010
    Default vBulletin 4.0.4 'postfoot' class issue
    The 4.0.4 release appears to have caused a problem with the 'postfoot' class (see attachment).
    The 'editpost', 'newreply', 'sendmessage' and 'printthread' roll-overs are misaligned and the last two have lost their roll-over effect.
    I'm having the exact same issue, does anyone know of a fix?
    There must be a way of editing the postbit.css, but it's beyond me. Anyone have any idea before I begin trial and error?
    Apr 2010
    I've been looking at it now and again since my first post. It looks to me as if there are a number of issues that need addressing. It might be that fixing one problem would sort out the rest but I have my doubts.
    Aside from the rollovers on 'sendmessage' and 'printthread' not working, the block in which they are contained is breaking out of its parent container. That's aside from the block of unwanted white space. (Check out my new attachment which shows the area enlarged.)
    There's a hard coded padding variable in postbit.css which if changed will drop the background colour (remove the white space) but it's a bit of dirty hack and I don't know if it'll impact elsewhere. You'll find the padding control immediately under...
    .postbit .postfoot .textcontrols, .postbitlegacy .postfoot .textcontrols, .eventbit .eventfoot .eventcontrols {
    padding: 6px 0 4px;
    Increasing the bottom padding (4px) by something like 3 or 4 or more will remove the white space.
    I'll take another look at this shortly to see if I can find a proper fix. Any suggestions would be most welcome.
    Apr 2010
    Further to my post above, vBulletin appears to have made changes to some of the StyleVar settings that are affecting those roll-overs mentioned.
    The colour setting in the postbit_control_background StyleVar seems to be masking the roll-over effect. Removing the value completely will reveal the roll-over but it's almost impossible to see, even on a properly calibrated monitor.
    If you also edit the control_background StyleVar and set the Background Color (currently set @ #e9e9e9) to something a little darker, say #999999, the roll-over effect becomes more obvious.
    I think that should be more in keeping with how the roll-over effect looked prior to patch 4.0.4.
    What is still perplexing me a little is why the container for that area is out of alignment. If I can work it out I'll leave another post.
    Thank you for pointing this out. If you will replace the contents of your 'adv_portal_newsbits' template with the following code then it should take care of the issue.
    <vb:if condition="!$mod_options['portal_news_legacy']">
    	<h2 class="blockrow">
    		<vb:if condition="$mod_options['portal_news_showicon']">{vb:raw vba_style.portal_blockbullet}</vb:if> {vb:raw news.prefix} <a href="{vb:raw vboptions.bburl}/{vb:link thread, {vb:raw news}}">{vb:raw news.title}</a>
    	</h2>
    <div class="<vb:if condition="$mod_options['portal_news_legacy']">blocksubhead<vb:else />blockrow</vb:if>">
    	<div<vb:if condition="$mod_options['portal_news_showrating'] AND $news['rating']"> class="vba_rating{vb:raw news.rating}"</vb:if>>
    		<vb:if condition="$news['subscribed'] AND $mod_options['portal_news_showsubscribed']">
    			<img alt="" class="inlineimg" src="{vb:stylevar imgdir_misc}/subscribed.gif" title="{vb:rawphrase you_are_subscribed_to_this_thread}" />
    		{vb:raw news.dateposted} - {vb:rawphrase by_x, {vb:link member, {vb:raw news}, null, 'postuserid', 'postusername'}, {vb:raw news.postusername}}
    <div class="blockrow">
    	<vb:if condition="$show['paperclip']">
    		<span style="float:{vb:stylevar right}">
    			<a href="#" onclick="vba_attach_win({vb:raw news.threadid}); return false"><img class="inlineimg" src="{vb:stylevar imgdir_misc}/paperclip.gif" border="0" title="{vb:rawphrase x_attachments, {vb:raw news.attach}}" alt="" /></a>
    		</span>
    	<table width="100%">
    			<td valign="top">
    				<vb:if condition="$news['avatarpath']">
    					<img align="{vb:stylevar left}" style="padding: 0 {vb:math {vb:stylevar padding}/2} {vb:math {vb:stylevar padding}/2} 0" alt="{vb:rawphrase xs_avatar, {vb:raw news.postusername}}" border="0" src="{vb:raw news.avatarpath}" />
    				<blockquote class="postcontent restore">{vb:raw news.message}</blockquote>
    	<vb:if condition="$show['signature']">
    		<div>__________________<br />{vb:raw news.signature}</div>
    <vb:if condition="$news['attachment']">
    	<div class="attachments">
    		<fieldset>
    			<legend>{vb:rawphrase attached_files}</legend>
    			{vb:raw news.attachment}
    		</fieldset>
    <div class="postbit">
    	<div class="postfoot" style="white-space: nowrap">
    		<div class="textcontrols floatcontainer">
    			<span class="postcontrols">
    				<vb:if condition="$show['editbutton']">
    					<a class="editpost" href="{vb:raw vboptions.bburl}/editpost.php?{vb:raw session.sessionurl}do=editpost&amp;p={vb:raw news.postid}"><img src="{vb:stylevar imgdir_button}/trans_40b.png" id="editimg_{vb:raw news.postid}" alt="{vb:rawphrase edit_delete_message}" /> {vb:rawphrase edit_post}</a>
    				<vb:if condition="$show['replybutton']">
    					<span class="seperator">&nbsp;</span>
    					<a class="quickreply" href="{vb:raw vboptions.bburl}/newreply.php?{vb:raw session.sessionurl}do=newreply&amp;t={vb:raw news.threadid}" rel="nofollow"><img id="replyimg_{vb:raw news.postid}" src="{vb:stylevar imgdir_button}/trans_40b.png" alt="{vb:rawphrase quick_reply_to_this_message}" /> {vb:rawphrase reply}</a>
    				<vb:if condition="$mod_options['portal_news_showsendfriend']">
    					<a href="{vb:raw vboptions.bburl}/sendmessage.php?{vb:raw session.sessionurl}do=sendtofriend&amp;t={vb:raw news.threadid}" rel="nofollow" style="padding: 0"><img alt="" border="0" src="{vb:stylevar imgdir_button}/sendtofriend.gif" title="{vb:rawphrase send_to_friend}" style="position: relative" /></a>
    				<vb:if condition="$mod_options['portal_news_showprintable']">
    					<a href="{vb:raw vboptions.bburl}/printthread.php?{vb:raw session.sessionurl}t={vb:raw news.threadid}" rel="nofollow" style="padding: 0"><img alt="" border="0" src="{vb:stylevar imgdir_button}/printer.gif" title="{vb:rawphrase show_printable_version}" style="position: relative" /></a>
    			</span>
    			<span class="postlinking">
    				<vb:if condition="$mod_options['portal_news_allowreplies']">
    					{vb:raw news.replycount} <vb:if condition="$news['reply_noformat'] == 1">{vb:rawphrase reply}<vb:else />{vb:rawphrase replies}</vb:if>
    				<vb:if condition="$mod_options['portal_news_showviews'] AND $mod_options['portal_news_allowreplies']"> | </vb:if>
    				<vb:if condition="$mod_options['portal_news_showviews']">
    					{vb:raw news.views} {vb:rawphrase views}
    			</span>
    <br />
    <br />
    Apr 2010
    Thanks Brian.
  1. Weird vBulletin forum Integration issue
    By Joshva2 in forum Troubleshooting & Problems
    Last Post: 12-11-2007, 03:10 AM
  2. Style Issue from vBulletin?
    By IoN6 in forum Troubleshooting & Problems
    Last Post: 10-18-2007, 12:16 PM
  3. PHPadsnew - CMPS - VBulletin Forum Issue
    By TEAMBAJAMARINE in forum Module & Modification Discussion & Requests
    Last Post: 01-09-2006, 09:34 PM
  4. first class cock up
    By xtreme-mobile in forum Troubleshooting & Problems
    Last Post: 10-04-2005, 04:02 PM
  5. Where is this CSS Class?
    By paul41598 in forum "How Do I..." Questions
    Last Post: 07-12-2005, 01:35 AM
