Thread: Restore links from csv
    Default Restore links from csv
    I made a mistake of backing up my links as a csv rather than sql from php myadmin and now i dont seem to be able to reimport them correctly.
    I think it is to do with the fact that some of the description fields contain either a ; or a , or a :
    so when i try to reimport the csv file it sees these as indications of termination of a field or line and the import doesnt work.
    Any ideas?
    after my teething problem with the new version (thanks for the quick reply to the ticket brian) i now realise that the improt a list of links feature is gong to be no good for me.
    when i try to import it comes back with an error to say i have not filled out the required fields. which of course i havnt because there is nowhere to fill them out here.
    So im back to csv imports.
    Anyone got any ideas on how i can do this.
    anyone please....
    I've just tested the import feature locally and it looks like there is a small bug that can occur when you have required custom fields. I've just applied the fix to the forum/includes/vba_links_functions_savelink.php file in the download package here though, so if you will download the files again and update that one on your server, that should take care of the issue.
  1. Restore Default Homepage
    By Schnee in forum Troubleshooting & Problems
    Last Post: 07-13-2009, 12:52 PM
  2. Restore template
    By werwolf in forum "How Do I..." Questions
    Last Post: 04-13-2009, 01:34 PM
  3. Please advice me the best way to restore my forum
    By Fredrik_Arvid in forum "How Do I..." Questions
    Last Post: 01-14-2007, 01:25 AM
  4. Restore to normal vBulletin
    By FrankieFive in forum Troubleshooting & Problems
    Last Post: 06-21-2005, 03:58 PM
  5. Backup/restore
    By o0oKARo0o in forum Chit Chat
    Last Post: 08-13-2004, 02:18 PM
