Results 1 to 20 of 20
Thread: Integration issue for users on IE6 & 7
    Feb 2008
    296
    Default Integration issue for users on IE6 & 7
    This is a strange issue. Some users are telling me that their display is all stuffed up on some of the pages of my site. I find that if I remove the integration on those pages everything is ok. The only common denominator I can find is that they are using either IE v6 or v7.
    This is what they are seeing:
    1. Replying to a thread - the reply box is to the right of the screen so the user has to scroll across to find it...scroll further again to see the CMPS right column that has been integrated with the page:
    Attachment 5944
    2. This is the New Posts page...I think it explains itself
    Attachment 5945
    The right column (as seen in screen shot 2 above) contains just images but if I remove it (i.e. remove the integration) both problems are fixed and the pages are displayed as they should.
    My adv_portal template contains 2 extra columns that are used in other areas of the site and is:
    {vb:stylevar htmldoctype}
    <html dir="{vb:stylevar textdirection}" lang="{vb:stylevar languagecode}" xmlns="http://www.w3.org/1999/xhtml">
    <head>
    {vb:raw headinclude}
    <vb:if condition="$pages['name'] == 'home'">
        <meta http-equiv="Cache-Control" content="no-cache" />
        <meta http-equiv="Pragma" content="no-cache" />
        <meta http-equiv="Expires" content="0" />
    <title>{vb:raw vboptions.hometitle} <vb:if condition="$pagetitle">- {vb:raw pagetitle}</vb:if></title>
    {vb:raw headinclude_bottom}
    </head>
    <body>
    {vb:raw header}
    {vb:raw navbar}
    <vb:if condition="$show['customizepagelink']">
    <!-- IB removed top padding -->
        <div align="{vb:stylevar right}" style="padding-bottom: {vb:stylevar padding}">
            <vb:if condition="$show['customizepage']">
                [<a href="javascript: reset_cmps_layout({vb:raw pages.pageid})">{vb:rawphrase reset_layout}</a>]
                [<a href="{vb:raw show.customizepagelink}">{vb:rawphrase exit_customization_mode}</a>]
            <vb:else />
                [<a href="{vb:raw show.customizepagelink}">{vb:rawphrase customize_this_page}</a>]
    <table align="center" cellspacing="0" cellpadding="0" width="100%">
        <tr valign="top">
            <vb:if condition="$show['left_column']">
                <td width="{vb:raw vba_style.portal_leftcolwidth}"<vb:if condition="$show['center_column'] OR $show['right_column']"> style="padding-{vb:stylevar right}: {vb:raw vba_style.portal_colspacing}px"</vb:if>>
                    {vb:raw home.leftblocks}
    <!-- IB added left center column -->
            <vb:if condition="$show['left_center_column']">
                <td valign="top" width="275px"<vb:if condition="$show['center_column'] OR $show['right_column']"> style="padding-{vb:stylevar right}: {vb:raw vba_style.portal_colspacing}px"</vb:if>>
                    {vb:raw home.left_centerblocks}
    <!-- end IB added left center column -->
            <vb:if condition="$show['center_column']">
                <td valign="top">
                    {vb:raw home.centerblocks}
    <!-- IB added right center column -->
            <vb:if condition="$show['right_center_column']">
                <td valign="top" width="225px"<vb:if condition="$show['center_column'] OR $show['left_column']"> style="padding-{vb:stylevar left}: {vb:raw vba_style.portal_colspacing}px"</vb:if>>
                    {vb:raw home.right_centerblocks}
    <!-- end IB added right center column -->
            <vb:if condition="$show['right_column']">
                <td valign="top" width="{vb:raw vba_style.portal_rightcolwidth}"<vb:if condition="$show['center_column'] OR $show['left_column']"> style="padding-{vb:stylevar left}: {vb:raw vba_style.portal_colspacing}px"</vb:if>>
                    {vb:raw home.rightblocks}
    {vb:raw footer}
    </body>
    </html>
    The right column that is in the integration just contains one template module with the template being:
    <div style="padding-bottom:6px;">
        <a target="_blank" href="http://www.Survival-Kits.com.au"><img src="../advertise/survival.jpg" alt="The Survival Center" /></a>
        <a target="_blank" href="http://www.skyranger.com.au/"><img src="../advertise/best_aircraft.jpg" alt="Best of aircraft" /></a>
        <a target="_blank" href="http://www.morganaeroworks.com.au/"><img src="../advertise/morgan.jpg" alt="Morgan Aeroworks" /></a>
        <a target="_blank" href="http://www.clearprop.com.au/"><img src="../advertise/clearprop.jpg" alt="Clear Prop" /></a>
        <a href="../pages/advertising.php"><img src="../advertise/advertise_here.jpg" alt="Advertise Here" /></a>
        <a target="_blank" href="http://www.raa.asn.au/operations/memberprof.html"><img src="../advertise/raalogo.gif" alt="Recreational Aviation Australia" /></a>
    <br />
    I don't see anything wrong with the adv_portal or the module templates so I am lost as to what may be causing this...unfortunately I use IE 8 and Firefox which don't have these issues so any help is appreciated.
    Thank you for pointing this out. I've done some testing locally and was able to narrow the issue down to the way vB handles their CSS for 2 different minor things on each page.
    I've just made some changes to the includes/vba_cmps_include_bottom.php file and the 'adv_portal.css' template in the download package here to correct this. If you will download the files from here again, upload the inlcudes/vba_cmps_include_bottom.php and admincp/vbacmps_install.php files to your server, and then go to the admincp/vbacmps_install.php file in your browser and select the option to reinstall the templates, then that should take care of the issue.
    Feb 2008
    296
    As always Brian you are on the ball and greatly support your fine achievements...I will download and update and get the users to test...thanks again mate!
    Jul 2010
    I have tried this but it has made no difference. Do I need to upload the 'adv_portal.css' file as well? How do I do that?
    That will reinstall the templates, including adv_portal.css.
    Feb 2008
    296
    users report that all is working ok now Brian...thanks
    Jul 2010
    Well unfortunately it doesn't work for my users. Is there something else I should be doing?
    I checked your source code and the adv_portal.css template seems to have been updated fine, so I'd suggest deleting the current includes/vba_cmps_include_bottom.php file from your server and then upload the new copy of that file from the download package here just to make sure the file was overwritten.
    Jun 2006
    9
    This fix worked in the forums but with private message integration users are still reporting that they have to scroll 2 feet to the right to hit the reply button.
    update: must have something messed up, fix didn't work on the forums. It only works when i remove integration.
    Feb 2008
    296
    I have a couple of users also saying that the fix works spasmodically so it seems there is another element to what is causing the issue...sorry Brian, I know these must be the worst kind of issues to fix...all caused by the ridiculous vb4
    Jun 2006
    9
    If you have the version of windows 7 that lets you do the virtual pc xp mode then get it. I think it comes with ie 6, make a backup of xp mode files, install ie 7. you can see first hand how bad integration looks with vb4 on ie7.
    I tried his fix above, rebuilding the templates with the latest vbadvanced zip file and nothing, still broke on ie 7.
    Feb 2008
    296
    Is there any news on a perm fix for this Brian?
    For the members that it's working sporadically for... Are they seeing the same page fine one minute and then seeing the issues another, or are they seeing the issue fixed on one page but not another?
    Feb 2008
    296
    The users that have complained I got them to upgrade to firefox...however I don't know about those that haven't complained or have left the site...sorry Brian but will let you know if I can get any more info for you
    Hi Brian,
    I also have some integration issues. As far as I know this only manifests when users use IE7. When people try to reply to a thread, the page gets a huge width. The WYSIWYG editor is shown in the middle of this huge empty page. Header shows correctly, footer shows correctly, recentthreads-module is smaller then normal, only the "middle block" of the page becomes huge. Also, when people want to use the quickreply, the quickreply box gets a huge width. When I remove the integration or disable vBa, all works fine.
    I don't know if this also is an issue when replying to a PM, because I haven't integrated that page.
    I added some screenshots. I don't know if this is related to the other problems in this thread, but it looked like this was the right place to post this.
    EDIT: By the way, I have a two-column layout. I don't use modules on the right side of the page.
    EDIT2: I've already tried the fix you suggested in this thread, but with no result unfortunately.
    Greetings,
    Ezra
    PS: Members confirmed to me that all is working fine with other browsers like Safari, Google Chrome and Firefox (haven't confirmed whether it happens with IE6 or IE8).
    Ezra - Would you mind submitting a support ticket via the Members' Area here so I can take a look at things? Things are working fine for me locally with the fix posted above, so I'm not really sure what to suggest without being able to see things myself.
    Apr 2006
    Quote Originally Posted by Ezswo View Post
    Hi Brian,
    Greetings,
    Ezra
    Brian, Ezra,
    As you might have read my topic i have posted some weeks ago. I have still the same issue which i can't seem to fix yet.
    Can you take a look at this further please? I can provide you all the access or information needed.
    Greatly appreciated,
    Best Regards,
    Karel
    Brian, Ezra,
    Best Regards,
    Karel
    Hi Karel,
    I've submitted a support ticket for this. When I know more or Brian has a fix for it, I'll let you know.
    Greetings,
    Ezra
    Apr 2006
    Hi Ezra,
    Did you received already an answer?
    I bumped my same issue once more :-)
    http://www.vbadvanced.com/forum/show...971#post191971
    Sorry I forogt to update the thread here...
    I've been looking into this and narrowed the newreply.php page down to an issue that can occur if [quote], [php], [code], or other such tags are used within one of the "preview" posts below the reply box. Something within vBulletin's CSS is really throwing things off, but unfortunately I'm not sure if there's going to be a good way to fix it other than not integrating those two files with the CMPS.
  1. issue with total users
    By worldwidereefer in forum Troubleshooting & Problems
    Last Post: 06-23-2010, 10:34 PM
  2. Integration Issue with 3.7.0 B3.
    By fkatzenb in forum Troubleshooting & Problems
    Last Post: 01-17-2008, 07:43 PM
  3. Most Users Online Issue
    By Frustrated in forum Troubleshooting & Problems
    Last Post: 09-11-2007, 04:57 AM
  4. CMPS integration with forums...problem with Mac users
    By Robert Carver in forum Troubleshooting / "How do I..." Questions
    Last Post: 09-27-2004, 09:14 PM
  5. Issue with the Online Users block
    By 35263526 in forum Troubleshooting / "How do I..." Questions
    Last Post: 08-21-2004, 07:40 PM
