Results 1 to 11 of 11
Thread: VBSEO Sitemap Addon?
    25
    Default VBSEO Sitemap Addon?
    I have VBSEO and would love to get Links Directory entries into my sitemap.
    Here is there example:
    http://www.vbseo.com/f44/media-libra...r-addon-43753/
    I was hoping I could get some help creating these ADD-ON's so I can include this content into my sitemap.
    Jul 2004
    Copenhagen
    741
    Have you tried this?
    http://www.vbadvanced.com/forum/showthread.php?t=32265
    It is for the v3 version, hopefully it also works for v4
    25
    I did, but I can not verify if this is actually working or not. How do I tell?
    25
    Exclamation
    Ping? Am I the only person using VBlinks with VB4?
    I tried the vb3 script, and get this error:
    Database error in vBulletin 4.0.8:
    SELECT * FROM links_categories WHERE private = 0;
    MySQL Error   : Table 'vbulletin.links_categories' doesn't exist
    Error Number  : 1146
    Request Date  : Saturday, December 4th 2010 @ 02:40:50 PM
    Error Date    : Saturday, December 4th 2010 @ 02:41:49 PM
    Script        : http://www.blincmagazine.com/forum/vbseo_sitemap/vbseo_sitemap.php
    Referrer      : http://www.blincmagazine.com/forum/vbseo_sitemap/index.php?rlist=true
    IP Address    : 76.98.245.155
    Username      : Unregistered
    Classname     : vB_Database
    MySQL Version :
    Check this out, and this should work.
    http://www.vbseo.com/f44/sitemap-vba...d-addon-40825/
    Make sure you edit the vbseo_sm_vba file url to reflect your site name.
    The file can be found here (forums/vbseo_sitemap/addons)
    In vbseo make sure you and the file to your addons, and run the site generator and you should be fine.
    Jan 2009
    Germany
    21
    Question
    This does not work on my forums.
    I use vBA links directory 4.2.0, vBulletin 4.1.1, vBSEO 3.5.2 and vBSEO sitemap generator 3.0.
    I do not use vBAdvanced CMPS und therefore i makes no sense to use the file for all vBAdvanced pages.
    Bevor the upgrade from vB3 to vB4 I had no problems including the links-URLs in the sitemap generator.
    ⇒ My question is:
    Where can I find a additional file to include (only) the links directory 4.2 URLs in vBSEO sitemap generator 3?
    The file I used bevor the upgrade of the forums software produces database errors as shown above when running the sitemap generator.
    You may be able to get the vB3 version working on vB4 by looking in your /forum/vbseo_sitemap/vbseo_sitemap.php file and removing this bit of code:
     WHERE private =
    Jan 2009
    Germany
    21
    Hmm,
    this bit of code is not included in the file /vbseo_sitemap/vbseo_sitemap.php on my forum ...
    Did you mean /vbseo_sitemap/addons/vbseo_sm_vba_links.php?
        $lnkg $db->query_read("SELECT * FROM " TABLE_PREFIX "adv_links_categories WHERE private = 0");
    Jan 2009
    Germany
    21
    O.k.,
    I deleted "WHERE private = 0" from the file /vbseo_sitemap/addons/vbseo_sm_vba_links3.php
    and used this file.
    This ist the result:
    http://adhs-chaoten.net/sitemap_addon_1.xml.gz (includes also calendar urls)
    As you can see: The urls in the sitemap are not correct
    (e.g.
    http://adhs-chaoten.net/ads-adhs-links/category-13/link-9/
    instead of
    http://adhs-chaoten.net/ads-adhs-links/allgemeine-selbsthilfe-deutschland-13/nakos-9/ )
    How can this be fixed now?
    Jan 2009
    Germany
    21
    Anyone?
    Jul 2004
    Copenhagen
    741
    Have you tried the new version for vb4?
    http://www.vbulletin.org/forum/showp...8&postcount=16
  1. vBSEO Sitemap Addon
    By aproape in forum Modifications
    Last Post: 04-09-2012, 02:21 PM
  2. vBSEO Sitemap Addon
    By larina in forum Modifications
    Last Post: 08-01-2010, 09:01 AM
  3. XML Sitemap
    By NickR in forum Pre-Installation Questions
    Last Post: 07-13-2009, 11:50 AM
  4. vBSEO sitemap and link directory
    By jauburn in forum "How Do I..." Questions
    Last Post: 03-29-2009, 08:16 AM
  5. Adding vBadvanced Dynamics to VBSEO Sitemap
    By FrontRunner in forum Troubleshooting & Problems
    Last Post: 10-10-2008, 11:20 AM
