Results 1 to 10 of 10
Thread: BT - Module: Most viewed and replied threads.
    Cool BT - Module: Most viewed and replied threads.
    BT - vBadvanced CMPS Module: Most viewed and replied threads
    BlackThorn Coding...
    Description:
    This will add a CMPS block to your vBadvanced CMPS portal page. It will display the "Most viewed and replied threads" based on threads view and reply count in your vBulletin forums. I've tested it and working awesome but I just suggest, you should use that module center column in your vBA CMPS Portal.
    -Version features:
    • Username link to profiles
    • Views counts
    • Reply counts
    • Thread starters
    • Thread starters avatars
      • Uses exec_switch_bg (reads {vb:raw bgclass} and returns the alternate table class)
      • only 1 query
      • vBA CMPS-CP options ---> (default options 10) however you can change it to X
        -Fixed Bugs
        • DB
        • Thread counts
        • Usernames
        • Avatars
        • No file edit
        • No file upload
        • Table class
        • TD class
        Tested on:
        • vBulletin 4.0.x
        • vBulletin 4.0.5 Tested
        • vBadvanced CMPS v4.0.0
        • vBadvanced CMPS v4.0.1
    INSTALL INSTRUCTIONS:
    Go to your Forums -> Admincp -> vBa CMPS / Download -> Upload Module -> Module to Upload -> Select mostviewedandrepliedthreads file .xml from your pc -> Than Submit.
    Support:
    Please click install, if you like this module abd DONATE.
    Best Regards,
    Reserved.
    Nov 2009
    11
    thanks, but database error with vb 4.1.1 version (Unknown column 'thread.dateline' in 'field list')
    Quote Originally Posted by Armadio View Post
    Same problem here. The issue is caused when you have a table prefix like vb_.
    In the XML file near line 61 change:
    thread.prefixid, title, dateline, views, replycount FROM " . TABLE_PREFIX . "thread ORDER BY views DESC LIMIT 0, $count");
    to:
    thread.prefixid, title, dateline, views, replycount FROM " . TABLE_PREFIX . "thread AS thread ORDER BY views DESC LIMIT 0, $count");
    Then remove the module and install again using edited XML. Fixed it for me.
    Twenty years from now you will be more disappointed by the things that you didn't do than by the ones you did do. So throw off the bow lines. Sail away from the safe harbor. Explore. Dream. Discover.
    Luse Media, LLC | 365 Adventure | Greener People | Great Green List
    Nov 2009
    11
    Very thanks
    BT - Thanks, marked as installed.
    Mar 2008
    Los Angeles, CA
    i tried to install this, but gave me a database error so I had to delete it.. nice concept though.
    http://www.WorldForMoms.com
    Online Community for Expecting Women, Moms, & Women in general.
    Dec 2013
    sorry buddy, no money no update
    How do you get it sorted to display recent threads?
    Oct 2016
    Thumbs up someone knows what and where can I find this mod ?????
    Hello
    Vbadvance I installed on my forum and I'm looking for a mod I have seen on another website
    I wonder here and there the expert forum
    Anyone know what this mod ???
    because I think it is to this thread, but I can not find the link (I have installed 4.2.3 vb)
    Thank you
    edit: edit: I can not upload the image. I know this is the mod. That is if anyone knows where I can download
  1. BT - Module: Most Viewed Profiles
    By BlackThorn in forum Add-On Modules (version 4.x)
    Last Post: 08-23-2010, 09:13 PM
  2. Most Viewed Today
    By mikeinjersey in forum Module & Modification Discussion & Requests
    Last Post: 11-01-2009, 12:33 PM
  3. Top 25 visited, rated, replied to by category?
    By tavenger5 in forum "How Do I..." Questions
    Last Post: 10-22-2009, 03:50 PM
  4. Most viewed thread
    By silveraden in forum "How Do I..." Questions
    Last Post: 08-01-2008, 02:47 PM
  5. List Latest NEW Threads, but not update after replied to
    By MortysTW in forum Troubleshooting / "How do I..." Questions
    Last Post: 05-13-2005, 08:35 PM
