Thread: My X doesn't work in Quick Nav
    Feb 2008
    Default My X doesn't work in Quick Nav
    My Dynamics install is called Articles so the Quick Navigation module has under the item "My Articles" (in the My Stuff block).
    Clicking on this just takes you to the index page yet the code is the same as in the Navbar which works ok
    Thank you for pointing this out. It looks like the variable for that link isn't being passed into the module for some reason. This will be corrected in the next release (v2.0.2), which should be available today.
    Or if you would rather apply the fix to your current version manually, just look in the fourm/vba_dyna_modules/dyna_navigation.php file for this line:
    ($hook vBulletinHook::fetch_hook('vba_dyna_modules_navigation_end')) ? eval($hook) : false
    And add this just Above it:
    $myentrieslink dyna_fetch_cat_url(0, array('userid' => $vbulletin->userinfo['userid'], 'title' => $vbulletin->userinfo['username']), 'member');
  1. Quick Links Drop Down Dose not Work
    By mehrdad229 in forum Troubleshooting & Problems
    Last Post: 06-16-2008, 05:57 PM
  2. Login does work/doesent work O.o
    By NeonG in forum Troubleshooting & Problems
    Last Post: 12-19-2006, 03:47 PM
  3. Quick reply doesn't work
    By Camz in forum Troubleshooting & Problems
    Last Post: 08-03-2006, 09:10 AM
  4. Turned off Quick Moderation module, and not it wont work anymore
    By cmiller1014 in forum Troubleshooting / "How do I..." Questions
    Last Post: 04-03-2005, 10:03 PM
