Results 1 to 5 of 5
Thread: Upgrading from 2.0.2 to 3.3.0
    Default Upgrading from 2.0.2 to 3.3.0
    Hi guys, i have Vbulletin 3.6.4 installed, with VBAdvanced 2.2.1, and VBA Links 2.0.2.
    I want to upgrade VBA Links to 3.3.0 and these are my questions:
    Is Vbalinks 3.3.0 compatible with vbadvanced 2.2.1 ?
    In the upgrade info says: "If upgrading from vBa Links Directory 2.x or 1.x, it is strongly recommended that you revert any templates that you have modified. Most all templates have been changed and the old templates will no longer work properly."
    It refers to vbalinks templates or vbulletin ones ?
    Yes, vBa Links 3.3.0 and vBa CMPS v2.2.1 are compatible, though I would still recommend upgrading to vBa CMPS v3.2.2 since the version you're running is over 4 years old.
    The message about reverting templates only refers to the vBa Links templates.
    How can i know if any vbalinks template was modified ? As i am not the original installer of the plugin
    link is www.nightclubber.com.ar/links
    thanks
    Go to Admin CP => Styles & Templates => Style Manager, and then click the << >> button next to the style you want to check. Find the "vBadvanced Links Directory Templates" group in the large select menu that appears and double-click it to expand the templates. Then just look down the list and see if any titles are marked in red.
    many thanks Brian.
  1. After upgrading to rc1.....
    By stormzone in forum Troubleshooting & Problems
    Last Post: 03-12-2010, 12:14 PM
  2. Upgrading from 3.0 to 3.0.1
    By cmb7684 in forum "How Do I..." Questions
    Last Post: 11-12-2008, 08:31 PM
  3. upgrading from 3.07-3.6.2
    By Delw in forum Feedback & Suggestions
    Last Post: 11-06-2006, 04:26 PM
  4. Upgrading to 3.5 from 3.0.8
    By dieselpowered in forum "How Do I..." Questions
    Last Post: 10-04-2005, 02:36 PM
  5. Upgrading to 305
    By Damas in forum Troubleshooting / "How do I..." Questions
    Last Post: 01-07-2005, 08:45 PM
