Thread: Category not set when clicking "Submit Entry" link from within a category
    359
    Default Category not set when clicking "Submit Entry" link from within a category
    after the fixation of appearing dyna navbar
    still submit entry not get the category id and the user have to choose the category
    when user for example browse:
    http://www.mysite.com/mmydyna/browsecategory.php?c=3
    he should when go to navbar to submit entry
    he should get this :
    http://www.mysite.com/mmydyna/newentry.php?c=3
    but he will get :
    Thank you for pointing this out. If you will edit your 'Process Navbar Replacements' plugin for vBa Dynamics through the Admin CP and replace the 'Plugin PHP Code' with the following that should take care of the issue.
    if (VBA_SCRIPT == 'dynamics' AND ADV_DYNA_PREFIX == 'adv_dyna')
        global
    $navbits$repfiles$dynanav;
    // ##### navbar replacements
    $repfiles = array();
    $navreplace = array(
    'find' => array(
    '"clientscript',
    '\'misc.php'
    'replace' => array(
    '"' $vbulletin->options['bburl'] . '/clientscript',
    '\'' $vbulletin->options['bburl'] . '/misc.php'
    $navreplace['find'][] = '\' . $vboptions[\'forumhome\'] . \'.php';
    $navreplace['replace'][] = '\' . $vboptions[\'bburl\'] . \'/\' . $vboptions[\'forumhome\'] . \'.php';
    replace_template_filenames('navbar'$navreplace);
    // stop the replacements from replacing search.php in the vBa Links navtabs template
    if ($search_repkey array_search('"search.php'$repfiles['find']))
            unset(
    $repfiles['find'][$search_repkey]);
            unset(
    $repfiles['replace'][$search_repkey]);
    // ##### Hook replacements (from navbar)
    $hookreplacenames = array(
    'navtab_start',
    'navbar_start',
    'navbar_after_getnew',
    'navbar_after_pm',
    'navbar_after_faq',
    'navbar_after_calendar',
    'navbar_community_menu_start',
    'navbar_community_menu_end',
    'navbar_after_community',
    'navbar_quick_links_menu_pos1',
    'navbar_quick_links_menu_pos2',
    'navbar_quick_links_menu_pos3',
    'navbar_quick_links_menu_pos4',
    'navbar_end',
    'navtab_middle',
    'navbar_getnew_menu',
    'navbar_getdaily_menu',
    'navtab_end'
        if (!empty(
    $repfiles))
            foreach (
    $hookreplacenames AS $hookr)
                if (!
    $template_hook[$hookr])
                    continue;
    $template_hook[$hookr] = str_replace(
    $repfiles['find'],
    $repfiles['replace'],
    // Add navbar link
    if ($vbulletin->options['adv_dyna_dyna_addnavbar'] OR (VBA_SCRIPT == 'dynamics' AND ADV_DYNA_PREFIX == 'adv_dyna'))
        global
    $popentrylinks$newentrylink$newpostslink$catid_int;
    $dyna_title $vbulletin->options['adv_dyna_dyna_title'];
    $dyna_homeurl $vbulletin->options['adv_dyna_dyna_homeurl'];
    $templater vB_Template::create('adv_dyna_navbar');
    $templater->register('catid_int'$catid_int);
    $templater->register('dyna_homeurl'$dyna_homeurl);
    $templater->register('dyna_title'$dyna_title);
    $templater->register('myentrieslink'$myentrieslink);
    $templater->register('newentrynavbits'$newentrynavbits);
    $templater->register('newentrylink'$newentrylink);
    $templater->register('newpostnavbits'$newpostnavbits);
    $templater->register('newpostslink'$newpostslink);
    $templater->register('orderby'$orderby);
    $templater->register('popentrylinks'$popentrylinks);
    $templater->register('vba_options'$vba_options);
        if (
    $vbulletin->options['adv_dyna_dyna_addnavbar'])
            if (
    VBA_SCRIPT == 'dynamics')
    $vbulletin->options['selectednavtab'] = 'vba_dyna_adv_dyna';
    $template_hook['navtab_' $vbulletin->options['adv_dyna_dyna_addnavbar']] .= $templater->render();
        else
    $dynanav $templater->render();
    359
    can you update the picage of vba dyna so i will update the plogin more eazy becaus e i have about 12 instances and it is difficult to use vbulletin edit and save and so on
    if it is eazy to update through reinstall the product plz tell me other wise i will do it as you wrote
    The admincp/vbadyna_install.php file has also been updated so you can use that to reinstall the plugins if you would prefer.
  1. Adding a More VISIBLE "Submit Link" BUTTON to the Browselinks Header
    By NashChristian in forum "How Do I..." Questions
    Last Post: 10-04-2010, 02:55 PM
  2. Error while clicking onto "Reply to Link" button
    By charis in forum Bugs From v4.0.0
    Last Post: 04-22-2010, 12:12 PM
  3. Clicking link from "View Link Details" causes error
    By Heika in forum Troubleshooting & Problems
    Last Post: 04-20-2009, 09:50 AM
  4. How to change "Submit a Link" to "Submit an Entry"?
    By Induslady in forum "How Do I..." Questions
    Last Post: 12-17-2007, 01:40 PM
  5. Cannot Save "Link Description" Category Options
    By rclark666 in forum Bugs From 2.0 Beta 2
    Last Post: 10-03-2006, 02:18 PM
