Thread: Installing 2nd instance display problem
    Feb 2008
    296
    Default Installing 2nd instance display problem
    I have installed Dynamics but when I go to install another instance during the install procedure this is what I see:
    Attachment 6146
    Thank you for pointing this out. It looks like there was a small issue where all of the settings phrases were not being queried correctly. I've went ahead and updated the admincp/vbadyna_install.php file in the download package here to include the fix. In your case, I'd just recommend going to the Admin CP => vBa Dynamics (your secondary instance) => Modify Settings and then look over the options there to make sure everything is set the way you would like. You'll find all of the same settings and more there, so you can still make any changes you missed during the install.
  1. Problem with second instance after upgrading
    By Shon in forum Troubleshooting & Problems
    Last Post: 01-12-2009, 12:28 PM
  2. Problem with 2nd instance module
    By kirkus-tat in forum Troubleshooting & Problems
    Last Post: 03-03-2008, 09:16 PM
  3. Multiple Instance License - Can I rename the Dynamics on the First Instance?
    By NashChristian in forum "How Do I..." Questions
    Last Post: 01-06-2008, 05:19 AM
