Thread: Link issue after upgrade to 4.1.1
    Question Link issue after upgrade to 4.1.1
    I just upgraded to vb4.1.1 from 4.1.0. I am using the latest dynamics.
    After the upgrade, some of my links in my navbar are now being prefaced by dynamics. In the past when this happened I could simply add the link to the navbar replacements area and it would solve the issue. Not this time.
    Only a couple of links are causing problems and I suspect that it is due to VB;s new updates to allow people to put the CMS and Blogs outside of the forum. I am not doing that and have not changed anything.
    The two links that no longer work correctly are:
    index.php (supposed to go to my vbadvanced CMPS page but is being directed to : dynamics/index.php)
    forum.php (same issue except it is forwarded to: dynamics/forum.php which doesn't exist.)
    Can you offer a way to fix this?
    I have worked on this for the past 10 hours and still no solution. Can someone let me know if you are also having this issue?
    I have checked the faqs and put the required things into the replacement areas. Dynamics still adds in the dynamics/ before the vbulletin link (forum.php) and the vBA CMPS link (index.php).
    This is a serious issue as there is no way for members to return to the forums once they visit the dynamics page. If there is not a solution, I will have to disable dynamics so I can turn my live forum on. Please help.
    Notice someone using the Links software from here is having the same issue. What is the solution? Anyone?
    Thank you for pointing this out. We should have a new version out very shortly that will include the fix for this. Until then, you should be able to look in your 'Process Navbar Replacements' plugin for this code:
        $navreplace['find'][] = '\' . $vboptions[\'forumhome\'] . \'.php';
    $navreplace['replace'][] = '\' . $vboptions[\'bburl\'] . \'/\' . $vboptions[\'forumhome\'] . \'.php'
    And add this directly below it:
    ['find'][] = 'vB_Template_Runtime::linkBuild("forumhome")';
    $navreplace['replace'][] = '\'' $vbulletin->options['bburl'] . '/\' . vB_Template_Runtime::linkBuild("forumhome")'
  1. Upgrade causes issue with plugin
    By coldblooded in forum Troubleshooting & Problems
    Last Post: 12-11-2008, 03:48 PM
  2. Upgrade issue
    By katie hunter in forum Troubleshooting & Problems
    Last Post: 05-12-2008, 04:27 PM
  3. Upgrade Issue
    By Shelby in forum Troubleshooting & Problems
    Last Post: 08-25-2007, 12:55 PM
  4. Upgrade Issue
    By suttercane in forum Troubleshooting & Problems
    Last Post: 10-10-2006, 03:30 PM
  5. Upgrade Issue
    By Rob Locke in forum Troubleshooting & Problems
    Last Post: 02-04-2006, 02:12 PM
