Thread: Quick Reply Issues
    359
    Default Quick Reply Issues
    (thread copied from the vBadvanced Dynamics forum since the same issue applies to vBadvanced Links Directory)
    hello after mass test in every single work for vb dynamic i have small issues here related to quickreply :
    1.when click icon for link or image it will show this image :
    it should give on the box words to describe what he should do , but we get : Undefined, the attachement will show what i mean
    2.when write quick reply i see that the whole page reload again , and some times it will redirect me to newreply to write someting , but even i get this newreply.php and cancel it and go back i see that the post was published
    i do not use and addon related to quickreply except video link and i disabled it and also the same issue
    and as i told you sometimes it works put it will reload the page again not full ajax , and sometimes it will redirect to newreply, the post hash undefiend occur when i use firefox 3.6
    i use firebug to see what happen and i think there are an issue , it will show :
    when click quick reply ,:
    E.posthash is undefined
    Line 11
    i tested again with unmodified style and get the same issue,
    359
    you can check it if you do not mind with the support ticket that i open it for other issues
    thank you very much
    359
    i think this issue may be related to 4.1.2 vbulletin version , i was not face this before upgrading
    only i need to get answer for if user add quick reply does he nned to reload the page again ? if yes why it is not work as quick reply of the threads in vbulletin which do not required to reload the page , in vba dynamics he will get reload automaticly but why it is not work as threads?
    also about :
    need to fixed i think may be related to language phrases
    359
    ok now i will explain exactly the issue for quick reply wich only related to vba dynamic and i disable all other products to test every thing :
    when entry has not any replies and user add first quick reply he will send again to newreply.php with error that he should write at least x characters
    but if the entry already have replies he will send quick reply and ofcourse with automaticly reload the page
    could you confirm if it is bug
    359
    Quote Originally Posted by deathemperor View Post
    the same issue with vba links , i think that may be related to latest releases of vba dynamics and vba links
    Thank you for pointing this out. I've just applied the fix to the files in the download package here, so you should be able to correct the issues by downloading the files again and uploading the dynamics/showentry.php file and forum/admincp folder to your server. Then go to the forum/admincp/vbadyna_install.php file in your browser, select the option to reinstall your templates, and that should take care of the issue.
    For vBa Links, you will need to donwload the files from here again, upload the links/showlink.php and forum/admincp/vbalinks_install.php files to your server, and then use the vbalinks_install.php file to reinstall your templates.
  1. Quick Reply Issues
    By deathemperor in forum Bugs & Issues From v2.1.0
    Last Post: 03-29-2011, 12:49 PM
  2. quick reply
    By dinodonk in forum Module & Modification Discussion & Requests
    Last Post: 03-27-2010, 11:22 PM
  3. Quick Reply issue!
    By KristerSwe in forum Bugs From v4.0.0 Beta 2
    Last Post: 03-18-2010, 11:44 AM
  4. Post Reply, quick reply, and other problems
    By ridinhighspeeds in forum Troubleshooting & Problems
    Last Post: 01-24-2007, 12:28 AM
  5. Quick reply doesn't work
    By Camz in forum Troubleshooting & Problems
    Last Post: 08-03-2006, 09:10 AM
