Thread: strange issues with navbar dyna
    359
    Default strange issues with navbar dyna
    hello i face 2 issues wuth navbar dyna:
    1.for new dyna that i install and some old , the post links for whatsnew?:
    for days it will give link to:
    myvbadyna.com/whatsnew/entries/3/
    for 3 days post as example
    it should give :
    myvbadyna.com/whatsnew/post/3/
    2.my old dyna which some of them has not added any new entries or posts since month
    it will give :
    array text
    and even i added enteries or post , this issue will disappear
    i try to rebuilt settings and also i disable many products but still this issue appear and this appear only for old instances of dyna which has old entries and even i add new it will not disappear , also id does not show days for what is new?
    in attachement i will show example for this second issue:
    359
    Thank you for pointing this out. If you will look in your 'adv_dyna_navbar' template for this code:
    						<vb:if condition="$vba_options['dyna_allowreplies']">
    							<li class="blocksubhead">{vb:rawphrase vba_new_posts}</li>
    							<li{vb:raw show.vba_li_menu_class}><a href="{vb:raw newpostslink}{vb:raw session.sessionurl_q}">{vb:rawphrase since_your_last_visit}</a></li>
    							<vb:each from="newentrynavbits" key="dayno" value="whatsnewlink">
    								<li{vb:raw show.vba_li_menu_class}><a href="{vb:raw whatsnewlink}" rel="nofollow">{vb:rawphrase last_x_days, {vb:raw dayno}}</a></li>
    							</vb:each>
    And replace it with this:
    							<vb:each from="newpostnavbits" key="dayno" value="whatsnewlink">
    							</vb:each>
    Then that should take care of the problem.
    359
    thanks fixed
  1. Dyna navbar missing
    By neverstop in forum Troubleshooting & Problems
    Last Post: 11-26-2010, 02:10 PM
  2. issues in dyna
    By deathemperor in forum Troubleshooting & Problems
    Last Post: 04-13-2009, 07:58 PM
  3. Strange login and cookie issues
    By BonsaiNut in forum Troubleshooting & Problems
    Last Post: 11-02-2007, 12:07 PM
  4. Strange double slash issues
    By RhinoForums.net in forum Troubleshooting & Problems
    Last Post: 06-06-2007, 01:36 PM
