Page 1 of 3 123 LastLast
Results 1 to 20 of 57
Thread: Sub-Nav bar not showing on homepage
    Aug 2010
    19
    Default Sub-Nav bar not showing on homepage
    Hello all,
    As the title states my sub nav bar is not showing, no text or link available...
    Website - http://fazedops.com/index.php
    Notice when you click on the forums they appear and operate fine? any ideas..
    many thanks
    Jan 2008
    Atlanta, GA
    444
    ok.. when on the CMPS pages, the SubNav only shows links for SubPages for the page you are viewing. It does not display the Forum SubNav. So I would say it is working as intended.
    OK, is there a way to add the links to the CMPS page?
    Aug 2010
    19
    Thanks all it works fine.
    DFORMS what type of link? Nav bar or block...
    The 'Forum Subnav' containing the following links:
    -New Posts
    -Private Messages
    -FAQ
    -Calendar
    -Community
    -Forum Actions
    -Quick Links
    Hers is an image of the area where I would like the 'Forum Subnav' to be displayed:
    I'm also missing the Navbar bottom border identified in the image with the thin red line.
    Thank you!
    Jan 2008
    Atlanta, GA
    444
    No solution found in the thread you posted : s
    Jan 2008
    Atlanta, GA
    444
    Quote Originally Posted by DFORMS View Post
    The solution is in this post - http://www.vbadvanced.com/forum/show...8&postcount=10
    You have to tweak it to fit your forums/VB Version though
    OK, I don't really know what I have to tweak to make it fit on a default style? When I use the code provided without trying to mod it it gives me this error:
    The following error occurred when attempting to evaluate this template:
    Parse error: syntax error, unexpected '.' in /mounted-storage/home127/sub008/sc75656-HUSF/quebecod.com/forum/includes/adminfunctions_template.php(5217) : eval()'d code on line 144
    This is likely caused by a malformed conditional statement. It is highly recommended that you fix this error before continuing, but you may continue as-is if you wish.
    What exactly do I have to modify in the code? Is there not a standard copy/paste version that will work?
    Thank you Dragonsys!
    Jan 2008
    Atlanta, GA
    444
    This is what my code looks like for the Default Style in vB v 4.1.4
    			<li>
    				<ul class="floatcontainer">
    					{vb:raw template_hook.navbar_start}
    					<vb:if condition="$show['searchbuttons']">
    						<vb:if condition="$show['member']">
    						<li><a href="search.php?{vb:raw session.sessionurl}do=getnew&amp;contenttype=vBForum_Post">{vb:rawphrase new_posts_nav}</a></li>
    						<vb:else />
    						<li><a href="search.php?{vb:raw session.sessionurl}do=getdaily&amp;contenttype=vBForum_Post">{vb:rawphrase todays_posts}</a></li>
    					{vb:raw template_hook.navbar_after_getnew}
    					<vb:if condition="$show['pmmainlink']">
    						<li><a href="private.php{vb:raw session.sessionurl_q}" rel="nofollow">{vb:rawphrase private_messages}</a></li>
    					{vb:raw template_hook.navbar_after_pm}
    					<li><a rel="help" href="faq.php{vb:raw session.sessionurl_q}" accesskey="5">{vb:rawphrase faq}</a></li>
    					{vb:raw template_hook.navbar_after_faq}
    					<li><a href="calendar.php{vb:raw session.sessionurl_q}">{vb:rawphrase calendar}</a></li>
    					{vb:raw template_hook.navbar_after_calendar}
    					<vb:if condition="$show['communitylink']">
    					<li class="popupmenu">
    						<a href="javascript://" class="popupctrl" accesskey="6">{vb:rawphrase community}</a>
    						<ul class="popupbody popuphover">
    							{vb:raw template_hook.navbar_community_menu_start}
    							<vb:if condition="$show['quick_links_groups']">
    								<li><a href="{vb:link grouphome}">{vb:rawphrase social_groups}</a></li>
    							<vb:if condition="$show['quick_links_albums']">
    								<li><a href="album.php{vb:raw session.sessionurl_q}">{vb:rawphrase pictures_and_albums}</a></li>
    							<vb:if condition="$bbuserinfo['userid']">
    								<li><a href="profile.php?{vb:raw session.sessionurl}do=buddylist"><vb:if condition="$show['friends_and_contacts']">{vb:rawphrase contacts_and_friends}<vb:else />{vb:rawphrase contacts}</vb:if></a></li>
    							<vb:if condition="$show['memberslist']">
    								<li><a href="memberlist.php{vb:raw session.sessionurl_q}">{vb:rawphrase members_list}</a></li>
    							{vb:raw template_hook.navbar_community_menu_end}
    						</ul>
    					</li>
    					{vb:raw template_hook.navbar_after_community}
    						<a href="javascript://" class="popupctrl">{vb:rawphrase forum_actions}</a>
    							<li>
    								<a href="{vb:raw $vboptions.vbforum_url}{vb:if "$vboptions['vbforum_url']", '/', ''}forumdisplay.php?{vb:raw session.sessionurl}do=markread&amp;markreadhash={vb:raw bbuserinfo.securitytoken}" onclick="return confirm('{vb:rawphrase mark_forums_read_confirm}')">{vb:rawphrase mark_forums_read}</a>
    							</li>
    							<li>
    								<a href="profile.php?{vb:raw session.sessionurl}do=editoptions">{vb:rawphrase edit_options}</a>
    							</li>
    							<li>
    								<a href="profile.php?{vb:raw session.sessionurl}do=editprofile">{vb:rawphrase edit_your_details}</a>
    							</li>
    						</ul>
    					</li>
    						<a href="javascript://" class="popupctrl" accesskey="3">{vb:rawphrase quick_links}</a>
    								<li><a href="{vb:link subscription}" rel="nofollow">{vb:rawphrase subscribed_threads}</a></li>
    								<li><a href="javascript://" onclick="window.open(getBaseUrl() + 'misc.php?{vb:raw session.sessionurl}do=buddylist&amp;focus=1','buddylist','statusbar=no,menubar=no,toolbar=no,scrollbars=yes,resizable=yes,width=250,height=300'); return false;">{vb:rawphrase open_contacts}</a></li>
    							<vb:if condition="$vboptions['forumleaders']">
    							<li><a href="showgroups.php{vb:raw session.sessionurl_q}" rel="nofollow">
    		<vb:if condition="$vb_suite_installed">
    			{vb:rawphrase view_site_leaders}
    		<vb:else />
    			{vb:rawphrase view_forum_leaders}
    	</a></li>
    							{vb:raw template_hook.navbar_quick_links_menu_pos1}
    							{vb:raw template_hook.navbar_quick_links_menu_pos2}
    							{vb:raw template_hook.navbar_quick_links_menu_pos3}
    							<vb:if condition="$show['wollink']">
    								<li><a href="online.php{vb:raw session.sessionurl_q}">{vb:rawphrase whos_online}</a></li>
    							{vb:raw template_hook.navbar_quick_links_menu_pos4}
    						</ul>
    					</li>
    					{vb:raw template_hook.navbar_end}
    				</ul>
    			</li>
    Try that
    WARNING: This will not display links to your SubPages if they exist. If you want both, then this will require more coding.
    Jan 2008
    Atlanta, GA
    444
    hmm looks like adv_portal_navtab_subpages is only called if there are existing subpages, so this probably will have to be in the adv_portal_navtab template instead.
    It worked on the CMPS page: http://quebecod.com. But, it's doubling up on all the other pages : s (forum index): http://quebecod.com/forum/forum.php.
    Jan 2008
    Atlanta, GA
    444
    add
    <vb:if condition="THIS_SCRIPT == 'CMPS'">
    to the top of the code and
    to the bottom of it
    No, still not working : s I've tried adding the code to my adv_portal_navtab_subpages and my adv_portal_navtab with the if statement:
    <!-- code // -->
    You would need "THIS_SCRIPT == 'adv_index'" within your condition.
    Alright, that worked at 90%! Thank you Dragonsys and Brian for the support The style (CSS) is not being applied on my the adv_index: http://quebecod.com/index.php. If you compare with the forum index: the padding is not the same, the arrow icons are different and there is no hover bg color for 'community', 'Forum Actions' and 'Quick Links'. How can I achieve the common look and feel?
    Again thank you so much for the support! I am new to VB and VBA but it's the platform I want my site/forum/members to migrate to.
    Here is my code for adv_portal_navtab:
    <li<vb:if condition="$tabselected"> class="selected"</vb:if>><a href="{vb:raw vboptions.vba_portal_homeurl}<vb:if condition="$cmps_page['name'] == 'home'">{vb:raw session.sessionurl_q}<vb:else />?{vb:raw session.sessionurl}{vb:raw vboptions.vba_portal_pagevar}={vb:raw cmps_page.name}</vb:if>" class="navtab">{vb:raw cmps_page.title}</a></li>
    <vb:if condition="$subpagelinks">
    {vb:raw subpagelinks}
    </ul>
    <vb:if condition="THIS_SCRIPT == 'adv_index'">
    <li>
    <vb:else />
    </ul>
    </li>
    <li>
    </li>
    <li>
    </li>
    <li>
    </li>
    </ul>
    </li>
    <li><a href="javascript://" onclick="window.open(getBaseUrl() + 'misc.php?{vb:raw session.sessionurl}do=buddylist&amp;focus=1','buddylist','statusbar=no,menubar=n o,toolbar=no,scrollbars=yes,resizable=yes,width=250,height=300'); return false;">{vb:rawphrase open_contacts}</a></li>
    <vb:else />
    </a></li>
    </ul>
    </li>
    </ul>
    </li>
    Is there a link to my CSS missing somewhere? Thanks for the help guys.
    ...this is a pain
    The padding and such seems to be the same to me, so I'm assuming you were able to figure out the issue?
    thanks for all the info..guys
    @ Brian will this be in the next release?
    or should this of been working already ?
    Backup Backup Backup.. Thats all I can say
  1. Homepage not showing.
    By rwoscott in forum Troubleshooting & Problems
    Last Post: 03-09-2010, 05:10 PM
  2. Module not showing up on homepage
    By Chimpie in forum Troubleshooting & Problems
    Last Post: 06-13-2009, 11:31 AM
  3. why isn't the css gradient showing on homepage?
    By dannykilla in forum Troubleshooting & Problems
    Last Post: 09-02-2008, 02:02 PM
  4. Homepage not showing for a usergroup
    By nymyth in forum Troubleshooting & Problems
    Last Post: 07-31-2007, 11:08 AM
  5. Images Not Showing w/ Homepage
    By kaskade in forum Troubleshooting & Problems
    Last Post: 05-01-2006, 11:41 PM
