Thread: Simple template showing as 'lean'
    Durham, UK
    177
    Default Simple template showing as 'lean'
    For some reason, even though I've set random and new listings to use the simple template, they are using the lean one instead. I've tried re-installing the templates, performing maintenance, but nothing works.
    Sim Fans UK - Sims downloads and discussion
    Sounds like you need to disable the 'Enable Dynamic Template Resizing' setting just below the 'Use Expanded Entrybit Template' setting for that module.
    Durham, UK
    177
    That's done it, thanks mate
  1. Rating in simple template
    By ibaker in forum Bugs & Issues From v2.1.0
    Last Post: 02-15-2011, 01:37 PM
  2. How do I make the title in recent threads (lean) a larger font size?
    By guttormson in forum "How Do I..." Questions
    Last Post: 12-02-2009, 11:50 AM
  3. Icons with Lean entrybit
    Last Post: 07-13-2009, 05:51 PM
  4. Simple PHP script showing up odd
    By mizuzbizuz in forum Troubleshooting & Problems
    Last Post: 05-14-2008, 10:03 PM
  5. New simple plug in, how to output result to CMPS template?
    By SneakyDave in forum "How Do I..." Questions
    Last Post: 04-03-2008, 12:54 PM
