Thread: Vb_error_lite_error
    Exclamation Vb_error_lite_error
    Hello
    I've upgraded to vb 4.1.7 and having problem with vba dynamics v 2.1.1, i'm getting the following error when i want to open attachments window.
    Vbulletin Message:
    VB_ERROR_LITE_ERROR
    Thank you.
    It looks like vBulletin decided to change the way some of their error functions work, and code that used to tell vB's backend to use a different template *if* there was an error now tells it that there's an error. You should be able to correct the issue though by looking in the dynamics/newattachment.php file for this line near the very top and removing it:
    define('VB_ERROR_LITE'true);
    Thanks Brian, problem is fixed.
    Jun 2009
    14
    THank you! I had the same problem as well!
