Results 1 to 11 of 11
Thread: Show Reputation
    Default Show Reputation
    Is no longer showing after the newest vb4.1.8 update..
    this was 4.1.7 postbit legacy reputation code.
    <span class="postbit_reputation" id="repdisplay_{vb:raw post.postid}_{vb:raw post.userid}">{vb:raw post.reputationdisplay}</span>
    it was changed to this for 4.1.8.
    <span class="postbit_reputation" id="repdisplay_{vb:raw post.postid}_{vb:raw post.userid}" title="{vb:raw post.username} {vb:raw post.level}">
    					<vb:each from="reputationdisplay" value="row">
    						<img class="{vb:raw row.class}" src="{vb:stylevar imgdir_reputation}/reputation_{vb:raw row.posneg}{vb:raw row.imgext}" alt="" />{vb:raw row.rowend}
    					</vb:each>
    				</span>
    vBadvanced CMP 4.1.2 reputation code .
    <vb:if condition="$bbuserinfo['reputationdisplay'] OR ($bbuserinfo['rank'] AND $mod_options['portal_welcome_rank'])">
    						<div style="float:{vb:stylevar right}">
    						<vb:if condition="$bbuserinfo['reputationdisplay']">
    							{vb:rawphrase rep_power}: {vb:raw reppower}
    							<div align="{vb:stylevar right}" style="padding-bottom:{vb:stylevar cellpadding}px">{vb:raw bbuserinfo.reputationdisplay}</div>
    thanks for any help on this matter..
    Hippy
    Backup Backup Backup.. Thats all I can say
    Jan 2010
    14
    Post
    Quote Originally Posted by r_hippy View Post
    					</vb:each>
    				</span>
    Hippy
    just like i post it heres a picture with the red arrow pointing at it and did try default no parent same issue so its not the styles i got since they styles seamus did get upgrade it as well to 4.1.8
    Attachment 6360
    Sep 2010
    Default not show the reputation icon
    After upgrade from 4.1.7 --> 4.1.8 in my forum does not show the reputation icon on "Welcome Block" CMPS v4.1.2.
    Templates Used :adv_portal_welcomeblock_lean, adv_portal_welcomeblock_expanded, postbit_reputation.
    From vb 4.1.8 the postbit_reputation template no longer exists.
    https://www.vbulletin.com/forum/entr...Bulletin-4-1-8
    How changed welcomeblock.php and adv_portal_welcomeblock_expanded in CMPS v4.1.2 for vb 4.1.8??
    For show rank in "Welcome Block" changed in /modules/welcomeblock.php
     $vbulletin->userinfo['rank'] = str_replace('src="', 'src="' . $vbulletin->options['bburl'] . '/', $vbulletin->userinfo['rank']);
    to
    $vbulletin->userinfo['rank'] = str_replace('src="', 'src="', $vbulletin->userinfo['rank']);
    not sure about the fix you posted but reputation still showing a Array
    Jan 2010
    14
    Same here that seems to be for rank we need Reputation fix not rank.
    We need ya Brian..
    thanks
    Nov 2011
    I have the same issue, I tried the suggested fix and it did not correct the problem.
    Thank you for pointing this out. I've just applied the fix to the forum/modules/welcomeblock.php file in the download package here, so if you will download the files from here again and update that one on your server, that should take care of the issue. Or if you would rather apply the fix manually, just look in the file for this code:
    if ($mod_options['portal_welcome_rank'])
    And add this just Above it:
        if ($vbulletin->options['simpleversion'] >= 418)
    $repimage '';
            foreach (
    $vbulletin->userinfo['reputationdisplay'] AS $rep)
    $repimage .= '<img class="' $rep['class'] . '" src="' $vbulletin->stylevars['imgdir_reputation']['imagedir'] . '/reputation_' $rep['posneg'] . $rep['imgext'] . '" alt="" />' $rep['rowend'];
    $vbulletin->userinfo['reputationdisplay'] = $repimage;
    Sep 2010
    Thank you Brian.
    Icons rep vba 4.1.2 with vb 4.1.8 are now in place.
    once again thanks Brian..
    Jan 2010
    14
    Smile
    Thanks Brian.
  1. Reputation Problem...
    By natecoupons in forum Troubleshooting & Problems
    Last Post: 01-10-2009, 01:14 AM
  2. New Reputation Comments
    By divided_by_fear in forum "How Do I..." Questions
    Last Post: 05-26-2006, 10:22 PM
  3. Need Help :Top (10) Reputation Module
    By f22s in forum "How Do I..." Questions
    Last Post: 02-11-2006, 03:01 PM
  4. Top (10) Reputation Module
    By Acido in forum Add-On Modules & Modifications
    Last Post: 08-26-2005, 11:16 PM
  5. Top reputation in stats
    By armkbdotcom in forum Add-On Modules & Modifications
    Last Post: 08-04-2004, 05:25 AM
