Results 1 to 8 of 8
Thread: Fatal error
    Default Fatal error
    hi
    I'm having this error when you try to add a new entry
    Fatal error: Call to undefined function prepare_newpost_attachmentbit() in /home/xxx/public_html/tutorials/newentry.php on line 1352
    I use: vBadvanced Dynamics v2.1.3 RC1 & vBulletin 4.1.8
    Thank you
    Oct 2011
    I have the same.Anybody can help?
    Oct 2011
    Any support?
    It looks like vBulletin decided to remove that function in v4.1.8. I've just updated the dynamics/newentry.php file in the download package here to include the fix, so if you will download the files from here again and update that one on your server, that should take care of the issue. Or you can just look in your dynamics/newentry.php file for this line and remove it:
    $newpost_attachmentbit prepare_newpost_attachmentbit();
    Oct 2011
    That worked fine.Thank you
    Thank you
    May 2009
    Charlotte, NC
    I'm having this problem with Dynamics 2.1.3 and vBulletin 4.1.9. I deleted the specified line, but now when I submit the page I get the following:
    Warning: require_once([path]/includes/functions_wysiwyg.php) [function.require-once]: failed to open stream: No such file or directory in [path]/dynamics/newentry.php on line 260
    Fatal error: require_once() [function.require]: Failed opening required '/serverpath/vbtest/includes/functions_wysiwyg.php' (include_path='.:/usr/local/lib/php-5.2.12/lib/php') in /serverpath/vbtest/dynamics/newentry.php on line 260
    Sure seems like Dynamics is still broken.
    Are you sure you're running vBa Dynamics v2.1.3? The code within the newentry.php file has been updated to call a different file if you're running vB 4.1.4+, so I'd suggest downloading the files from here again, then delete the dynamics/newentry.php file from your server and re-upload the file from the package you just downloaded to make sure you're running the current version.
  1. Fatal Error - BB Code Error.
    By Lilmikeishere in forum Troubleshooting & Problems
    Last Post: 03-07-2009, 09:00 PM
  2. fatal error
    By michigan033 in forum Troubleshooting & Problems
    Last Post: 07-28-2008, 05:25 PM
  3. Fatal Error!!
    By elroger in forum Troubleshooting & Problems
    Last Post: 05-31-2006, 04:13 PM
  4. Facing Error Fatal error ....Please help.
    By admans in forum Troubleshooting & Problems
    Last Post: 10-15-2005, 03:00 PM
  5. Parse error (adminfunctions_template) and a fatal error (vbacmps_install)
    By Kizzmet in forum Troubleshooting / "How do I..." Questions
    Last Post: 09-30-2004, 06:16 PM
