Results 1 to 9 of 9
Thread: Invalid Redirect
    Default Invalid Redirect
    Just installed vba cmps yesterday, 3.2.2 onto a new forum vb3.8.7 all is working fine except occasionally when you login from the cmps page it gives the following message after it tells you that you have logged in sucessfully:
    Invalid Redirect URL (www.sitename.com...........
    Only seems to happen occasionally but its bloody annoying, it does log me in alright and if I ignore this and hit the forum link ) Im logged in as usual.
    Bump
    Is this when logging in from the navbar or from the Welcome Block module? Does it make a difference if you try logging in from cscgaming.net vs www.cscgaming.net?
    Both IIRC.
    Still happening.
    Invalid Redirect URL (http://cscgaming.net/index.php)
    I'm having the same issue. Login from the forum works fine, but from the vBAdvanced homepage occasionally gives me and some users that error.
    I'm running 3.2.3 with vBulletin 3.8.7PL2
    I was advised (elsewhere) put this in my .htaccess and it works fine now.
    RewriteEngine On
    RewriteCond %{HTTP_HOST} ^sitename.com
    RewriteRule (.*) http://www.sitename.com/$1 [R=301,L]
    Default Easy Fix :)
    Go to your Forums Admin C-Panel. On top, open SETTINGS tab and follow instructions below.
    Settings -> Options -> Site Name / URL / Contact Details.
    Under "Always use Forum URL as Base Path", Change "Yes" to "No". This allows you to login without the error.
    Credits: "BirdOPrey5" from VBulletin.
    Thank you very much, this solution worked for me!!!
    I jusr created a .htaccess with notepad and pasted in your code and everything works now!!
  1. Invalid Redirect URL Error on All Links
    By Don Z. in forum Bugs & Issues
    Last Post: 05-30-2012, 10:54 AM
  2. Invalid Redirect URL
    By mrderanged in forum Troubleshooting & Problems
    Last Post: 08-05-2011, 10:44 PM
  3. Invalid - invalid URL error?
    By Planet vB in forum Troubleshooting & Problems
    Last Post: 11-28-2007, 11:47 AM
  4. Redirect.
    By wishdragon in forum Troubleshooting & Problems
    Last Post: 09-27-2006, 02:10 PM
