Results 1 to 12 of 12
Thread: vBadvanced CMPS and v3 arcade
    Exclamation vBadvanced CMPS and v3 arcade
    ok my scores will not save because i am running vBadvanced CMPS,
    any idea's? or just change back to ipro-arcade?
    anyone please??????????
    mmm i have not seen anyone with CMPS using v3 im wondering maybe this cant be done.
    Sep 2005
    145
    Thats not v3arcade´s fault, im using it with no trouble at all.
    Why do you think it are v3arcade´s fault?
    what happens then the game try to submit?
    yep i tryed 3 games and all would not submit because CMPS is enabled.
    disable and they score fine so CMPS is the problem.
    and mate did i say it was v3 arcades fault? whats v3 arcades fault? what are you on about?
    for ipro-arcade you have to put a code in the index.php (CMPS) in order for the games to submite!
    my question if anyone understould, is "do you have to put a code in index.php (CMPS) for the scores to submite because with CMPS enabled the score to not submite.
    easyer enough to understand?
    There should be a plugin installed (If I am not mistaken) that redirects IBpro game submits. Make sure that is enabled in your plugins.
    You would need to add the hook code to the vbAdvanced or use portal.php for your portal. There is a post around here somewhere. Try doing a search.
    thanks, you would think the code would come with the package like ipro-arcade.
    i cant find the code to put there. i'll keep looking.
    ok found it thanks to the members that new what i was talking about lol.
    worked perfect
    find : in index.php CMPS
    require_once('./global.php');
    after add:
    // ######################## START MAIN SCRIPT ############################
    ($hook = vBulletinHook::fetch_hook('forumhome_start')) ? eval($hook) : false;
    I've never had a single issue with vBa CMPS and I've been using it since I first started using v3arcade. One of the two is probably installed incorrectly. =/
    Sep 2005
    145
    Ops Sorry i edited my post so many times i forgot what you question was
    Quote Originally Posted by LaZaIsDaBeSt View Post
    Quote Originally Posted by Phooey View Post
    lmao yeah yeah m8, someone who no's it all, wow your a champ you probley havent upgraded yet.
    =/ << this really shows ya age
    Quote Originally Posted by Mario View Post
    no worrys man all good thx
