Thread: Force style for v3 Arcade
    Feb 2009
    Default Force style for v3 Arcade
    Does anyone know if it's possible to force the use of one style for the v3 Arcade.
    If it's possible, I'd be most grateful if someone could post the code that will force the style by using it's ID.
    TIA
    Feb 2009
    Default Re: Force style for v3 Arcade
    Sorry for bumping this. Anyone!
    Mar 2009
    15
    Lightbulb Re: Force style for v3 Arcade
    It`s not difficult!!!
    Create new plugin:
    Choose product V3 arcade
    location style_fetch
    Insert code:
    if (THIS_SCRIPT=='arcade')
    {$styleid=XXX;}
    Where XXX = id your custom style
    for example if i want set style with id =43 i insert code
     {$styleid=43;}
    Enable plugin and save it.
    Feb 2009
    Default [solved] Force style for v3 Arcade
    Thank you Lusik, that worked exactly as it says on the tin.
    Just what we required .
    Kudos !
    May 2009
    Nice !
    Apr 2006
    Cheers, it does exactly what it says on the tin.
