Results 1 to 13 of 13
Thread: Plain white screen
    Default Plain white screen
    After installing my links directory with links in the forum root all I get is a blank white page, my config.php seems to be ok as i did the forum path thing... I know its probably something simple but I've tried all different combination of urls for example
    http://www.midlandsheritage.co.uk/links
    http://www.midlandsheritage.co.uk/forum/links
    http://www.midlandsheritage.co.uk/forums/links
    etc etc anybody got any suggestions??
    What do you have entered for your $forumpath in the links_config.php file?
    The forumpath.php gives this
    /var/www/vhosts/midlandsheritage.co.uk/httpdocs
    done by viewing this-
    http://www.midlandsheritage.co.uk/forumpath.php
    so the links_config .php has all this on-
    <?php
    // || vBadvanced Links Directory v3.3.1 (vB 3.6 - 3.8) - 101314
    // || © 2003-2012 vBadvanced.com - All Rights Reserved
    // || This file may not be redistributed in whole or significant part.
    // || http://www.vbadvanced.com
    // || Downloaded 16:29, Sat Feb 4th 2012
    // || 970101314_202459063663
    error_reporting(E_ALL & ~E_NOTICE & ~8192);
    // Enter the full path to your forum here
    // Example: /home/yoursite/public_html/forum
    $forumpath = '/var/www/vhosts/midlandsheritage.co.uk/httpdocs';
    1,694
    Try removing the parenthesis ....
    $forumpath = /var/www/vhosts/midlandsheritage.co.uk/httpdocs
    Quote Originally Posted by CareyCrew View Post
    I removed the whole thing still no good
    anybody else got any suggestions as I'd really like to get this working
    1,694
    Try entering just a period in the brackets like this (.)
    do you mean the brackets here-
    I think one problem is that my links_config.php file is actually links_config.php.new, how the hell do I change that? I'm starting to get very frustrated
    1,694
    Quote Originally Posted by yamahapaul View Post
    Ahh, well that would cause a problem. You should be able to rename that file in your FTP client or your Plesk file manager.
    So, rename and start again with the file path set as /var/www/vhosts/midlandsheritage.co.uk/httpdocs and see what happens.
    May 2008
    Sarasota, Florida
    302
    Do you mean get rid of the .new? Just rename the file.
    CHIMPIE | SKYWARN
    "I have found Chimpie to be very professional, knowledgeable, prompt, and reasonably priced."
    "I would not hesitate to utilize his services again in the future, and I highly recommend him."
    Still no good
    Try this:
    $forumpath '../'
    Try this:
    $forumpath '../'
    Thanks Brian it worked
  1. Submit and White screen
    By braindeegee in forum Troubleshooting, Problems, Questions
    Last Post: 11-21-2010, 09:47 PM
  2. Installed vBadvanced Links and have a white screen
    By clubplanet in forum Troubleshooting & Problems
    Last Post: 06-06-2010, 07:53 AM
  3. White screen after install [php 5.3.2]
    By neverstop in forum Troubleshooting & Problems
    Last Post: 05-24-2010, 03:05 AM
  4. Only white screen during install
    By Tolden in forum Troubleshooting & Problems
    Last Post: 09-15-2009, 08:36 AM
  5. Plain text...
    By OllieRocks in forum Troubleshooting, Problems, Questions
    Last Post: 11-27-2005, 04:22 PM
