Results 1 to 8 of 8
Thread: How to - add links to vBa Home subnav
    Oct 2007
    t.dot b.dot
    34
    Question How to - add links to vBa Home subnav
    I recently installed vBa CMPS 4.2.0 and would like to add some of the links to the subnav bar of Home tab like there are on the Forum tab. See attachments.
    I would like to add: FAQ, Calendar, Community, Quick Links, Forum Rules, and Donate links
    to the vBa Home tab subnav bar.
    Any help is greatly appreciated, I'm not sure what code I need to copy and what templates they are in.
    Warm Regards,
    Marc
    TBMOTORING - Thunder Bay Automotive Enthusiast Club
    http://tbmotoring.com
    You can manually add additional links by editing the 'adv_portal_navtab' template.
    Oct 2007
    t.dot b.dot
    34
    Thanks for the help, Brian.
    I tried adding this:
    <li><a href="http://tbmotoring.com/bppl_donate.php?{vb:raw session.sessionurl}">Donate</a></li>
    to 'adv_portal_navtab' template but it to shows up in the navbar, not the subnav? I must be using the wrong code, or putting it in the wrong place. What code should I insert and where to get it to display in the subnav?
    Oct 2007
    t.dot b.dot
    34
    I'm really stuck with this. Any advice would be appreciated.
    Feb 2008
    296
    Did you have any luck with this?
    I too have edited my template and the sub nav items are not showing...my template:
    <li<vb:if condition="$tabselected"> class="selected"</vb:if>><a href="{vb:raw vboptions.vba_portal_homeurl}<vb:if condition="$cmps_page['name'] == 'home'">{vb:raw session.sessionurl_q}<vb:else />?{vb:raw session.sessionurl}{vb:raw vboptions.vba_portal_pagevar}={vb:raw cmps_page.name}</vb:if>" class="navtab">{vb:raw cmps_page.title}</a></li>
    <vb:if condition="$subpagelinks">
        <ul class="floatcontainer">
            {vb:raw subpagelinks}
            <vb:if condition="$show['searchbuttons']">
                <vb:if condition="$show['member']">
                <li><a href="search.php?{vb:raw session.sessionurl}do=getnew&amp;contenttype=vBForum_Post">{vb:rawphrase new_posts_nav}</a></li>
                <vb:else />
                <li><a href="search.php?{vb:raw session.sessionurl}do=getdaily&amp;contenttype=vBForum_Post">{vb:rawphrase todays_posts}</a></li>
        </ul>
    1,694
    Jan 2008
    Atlanta, GA
    444
    Read through this, it should get you started in the right direction: http://www.vbadvanced.com/forum/showthread.php?t=43898
    Feb 2008
    296
    Thanks mate...that helped!
  1. Change Home Logo - Back to Forums Home not Links Home
    By interfx in forum "How Do I..." Questions
    Last Post: 06-23-2008, 02:30 PM
  2. Search and Quick Links/Menu links not working on home
    By chaotic_geo in forum "How Do I..." Questions
    Last Post: 06-13-2008, 09:19 PM
  3. Forum home links not pointing to portal home page
    By cbiweb in forum Troubleshooting & Problems
    Last Post: 07-31-2007, 09:25 AM
  4. Links on Forum Home
    By nealparry in forum Modifications
    Last Post: 05-01-2006, 09:28 PM
  5. top links on forum home
    By swa in forum "How Do I..." Questions
    Last Post: 12-24-2005, 12:05 PM
