Results 1 to 11 of 11
Thread: Navbar Overlap Issue
    Sep 2005
    Default Navbar Overlap Issue
    Just installed yesterday and this is the first thing i see, i have adjusted Nav bar setting from Start to Middle to End and it still does this overlap of sublinks things. thanks for any direction to resolve this matter... Jim
    Yup, I have multiple installs of Dynamics and I also have Links, they are all doing it.
    i had posted a thread of the same issue with vblinks and vbadvanced
    but no responses since 2 weeks.
    i think vBadvanced is dead
    Quote Originally Posted by bela-meaad View Post
    No yet I hope, there are very few companies that have survived for more than a few years, I thought vBa would be the exception. I've used products from vbgeek, vblogetin, and vbclassifieds - all gone now. They all made high quality product just like Brian, I fear there isn't enough money in it for them.
    Sep 2005
    i see that,, i paid to renew for this?
    I too paid to renew my products and hope there is a fix soon.
    Brian, please correct the menu for the products.
    250
    A fix would be nice.
    I tried to add a plugin like other scripts are using but without success.
    hook: set_navigation_tab_fallback:
    if (defined('VBA_SCRIPT') AND VBA_SCRIPT == 'links_directory')
    $root = 'vba_links';
    Thank you for pointing this out, it looks like a plugin was accidentally left out of the last release. You can correct the problem by downloading the files from here again, uploading the admincp/vbalinks_install.php file to your server, then going to it in your browser and selecting the option to reinstall the vB plugins. Or, you can just add a new plugin with the following values:
    Product: vBadvanced Links Directory
    Hook Location: navigation_tab_complete
    Title: Nav Tab
    Execution Order: 5
    Plugin PHP Code:
    if (VBA_SCRIPT == 'links_directory')
    $tabid 0;
    Active: Yes
    250
    Yep, that's it, thanks Brian.
    that's work perfect with vBlinks ... what about vBadvanced still having the same problem.
    This is solved ... Solution is here:
    http://www.vbadvanced.com/forum/show...09&postcount=2
  1. Quote Tags Overlap Avatar in News
    By 123LearnToTrade in forum Bugs From v4.0.0
    Last Post: 05-24-2010, 11:10 AM
  2. Navbar issue
    By OrionsMom in forum Troubleshooting & Problems
    Last Post: 03-08-2008, 09:53 AM
  3. Navbar issue
    By transburgh in forum Troubleshooting & Problems
    Last Post: 11-27-2006, 12:17 PM
  4. Right-side modules overlap
    By afkae in forum Troubleshooting & Problems
    Last Post: 08-09-2005, 10:49 AM
  5. How do I stop main frame overlap?
    By garyhartaz in forum Troubleshooting / "How do I..." Questions
    Last Post: 08-19-2004, 05:49 PM
