Results 1 to 5 of 5
Thread: Sub Menus of two Two Menus displaying at the same Time
    Default Sub Menus of two Two Menus displaying at the same Time
    After recently upgrading to vB 4.2.0. I see that two separate menu - sub menus run over each other. See the menu for these two menu labels: 'Books and Videos' and 'Links'
    http://namaskar-africana.com/dynamics/index.php
    It appears that the 'Forum' Menu's sub menus run over the other two. The Forum Menu is still highlighted even after either of the other two Menu's are selected.
    Any suggestions, how I might fix this ?
    cammot
    Thank you for pointing this out, it looks like a plugin was accidentally left out of the last release. You can correct the problem by downloading the files from here again, uploading the admincp/vbadyna_install.php file to your server, then going to it in your browser and selecting the option to reinstall the vB plugins. Or, you can just add a new plugin with the following values:
    Product: vBadvanced Dynamics
    Hook Location: navigation_tab_complete
    Title: Nav Tab
    Execution Order: 5
    Plugin PHP Code:
    if (VBA_SCRIPT == 'dynamics')
    $tabid 0;
    Active: Yes
    Thanks Brian. That works perfect !. Appreciate it.
    The only pending issue, is that I still have the problem with the 'Links' tab. Is there a code that you can provide like you did for the Dynamics ?.
    It's the same for vBa Links, except you use this for the first line of the plugin PHP code:
    if (VBA_SCRIPT == 'links_directory'
    Thanks Brian - It worked - many thanks.
  1. Link menus
    By Magz in forum Troubleshooting & Problems
    Last Post: 08-16-2010, 03:18 PM
  2. Navigation Menus
    By dieselpowered in forum "How Do I..." Questions
    Last Post: 11-24-2007, 10:25 AM
  3. Menus Behind Modules
    By dieselpowered in forum Troubleshooting / "How do I..." Questions
    Last Post: 07-22-2005, 07:56 PM
  4. New Menus ...
    By Zantheus in forum "How Do I..." Questions
    Last Post: 06-29-2005, 01:16 PM
  5. drop menus
    By GameTavernNeo in forum Troubleshooting / "How do I..." Questions
    Last Post: 01-12-2005, 03:53 PM
