Thread: Issue with Menu Tabs
    Feb 2012
    Default Issue with Menu Tabs
    For some reason, my vB installation thinks that the home page is also apart of the forum, but its not.
    Normally, when you are browsing the forum, only the forum tab is highlighted.
    But when on the home page, both tabs are highlighted. Anyone know how to fix this?
    See attached image.
    Would appreciate any help,
    Justin
    Thank you for pointing this out. This has been fixed already in the download package, and those who have already installed can correct the issue by adding a new plugin with the following values:
    Product: vBadvanced CMPS
    Hook Location: navigation_tab_complete
    Title: Nav Tab
    Execution Order: 5
    Plugin PHP Code:
    if (VBA_SCRIPT == 'CMPS')
    $tabid 0;
    Plugin is Active: Yes
    Feb 2012
    Works great! Thank you very much sir!
  1. Popup Menu Issue
    By sdfontanini in forum Troubleshooting & Problems
    Last Post: 12-23-2009, 04:31 PM
  2. Minitabbars * Dropdown Menu * Rainbow Tabs
    By Deepdog009 in forum Modifications (version 3.x & 2.x)
    Last Post: 01-18-2009, 10:40 AM
  3. How to change the top menu / header menu
    By pieter.burm in forum "How Do I..." Questions
    Last Post: 08-13-2008, 07:42 AM
  4. Another Menu Issue
    By ozwebsites in forum Troubleshooting & Problems
    Last Post: 06-10-2008, 03:33 AM
  5. Login on Top Menu Issue
    By dleblanc in forum Troubleshooting / "How do I..." Questions
    Last Post: 02-04-2005, 06:30 PM
