Thread: Install Problem: The Service is Unavailable
    Oct 2009
    Default Install Problem: The Service is Unavailable
    Hello,
    I have many vBulletin 3.8 boards, and am creating a new one now. While trying to install vBadvanced CMPS 3.2.3 I keep bumping my head into an white screen with "The Service is Unavailable".
    Site: http://c3.register.pac.org
    vBulletin Version: 3.8.7 P3
    PHP Version: 5.3.13
    MySQL Version: 5.5.23
    I ran into this problem with the last board I setup, and if I recall correctly it turned out to be an incompatibility with the latest MySQL not supporting the 'TYPE' query. How can I find the source of that query so I can change it to 'ENGINE'?
    Thanks in advance for the help.
    Oct 2009
    I found the error. The Install PHP script was not properly reading the MySQL version. If you too are having this problem, search your vbacmps_install.php (found in admincp folder) file for:
    $enginevar 'TYPE'
    and replace it with:
    $enginevar 'ENGINE'
    This will force it to use the ENGINE command instead of the TYPE (now obsolete) command.
    Once you make that change, run your install script and all should work.
  1. Advanced Options Unavailable
    By Kapeket in forum Troubleshooting & Problems
    Last Post: 04-07-2010, 03:14 PM
  2. how long has the game store been temp unavailable?
    By imported_ego in forum Troubleshooting, Problems, Questions
    Last Post: 12-15-2009, 09:30 PM
  3. vBadvanced version information is currently unavailable.
    By Saviour in forum Troubleshooting & Problems
    Last Post: 06-29-2009, 06:05 PM
  4. What is up with the Service?
    By ant0nio in forum Site Feedback & Updates
    Last Post: 03-28-2006, 03:17 AM
