Thread: Links Navbar missing
    Default Links Navbar missing
    I am running 4.2.7, and my navbar is missing. Should I just import the xml again?
    http://www.teambuick.com/links/
    Mmm... there is no xml...
    Could it be a problem with a template? What approach to solving the problem should I use?
    missing are:
    Submit A Link / What's New / What's Popular / Search --- the whole navbar
    as seen on other pages like: http://www.vbadvanced.com/links/index.php
    [I]I would like to have the navbar![I]
    What am I missing?
    How can I get help?
    Thanks for the fix Brian!
    In case this problem effects anyone else it turns out that Vbulletin no longer likes the "middle" setting in the "Navbar Link Position" found under Modify Settings - Main Options. Just set it to "None".
    Thanks again.
  1. Navbar arrows missing
    By Reverend in forum Troubleshooting & Problems
    Last Post: 04-28-2013, 06:54 PM
  2. Moderate Link is missing in Navbar
    By abroad in forum Troubleshooting & Problems
    Last Post: 12-07-2010, 01:08 AM
  3. Dyna navbar missing
    By neverstop in forum Troubleshooting & Problems
    Last Post: 11-26-2010, 01:10 PM
  4. Entire Navbar & Banner Missing
    By Toups in forum Troubleshooting & Problems
    Last Post: 08-18-2008, 07:10 PM
  5. Navbar missing
    By ricktas in forum "How Do I..." Questions
    Last Post: 12-02-2007, 02:33 PM
