Results 1 to 15 of 15
Thread: Call to undefined function print_portal_output()
    Durham, UK
    177
    Default Call to undefined function print_portal_output()
    I've tried to access my site today, but receive the following error message:
    [22-Oct-2013 21:04:47] PHP Fatal error:  Call to undefined function print_portal_output() in /home/******/public_html/sims/cmps_index.php on line 46
    Sim Fans UK - Sims downloads and discussion
    Was the CMPS running fine before today? Have you disabled all plugins, or any of the CMPS plugins or the product in your Admin CP?
    Was there a solution to this? I just installed on 4.2.2. I get a similar error. Yes, the product and all plugins are active.
    Fatal error: Call to undefined function print_portal_output() in /var/www/virtual/enworld/forum/content.php on line 46
    (A search reveals dozens of threads with problems similar to this, but none with any solution in them).
    Try going to the Mange Products link in your Admin CP, disable the CMPS product and then enable it again. If that doesn't help then you may want to double-check your $forumpath variable.
    http://www.vbadvanced.com/forum/faq....uble_forumpath
    I've not only done that a hundred times, I've installed and uninstalled the entire product more than once, too. The forumpath is correct.
    Apr 2006
    This is due to 4.2.2 by default, it's a warning.
    Add this:
    define('SKIP_ALL_ERRORS'true);
    to your config.php and it'll solve the issue.
    I'm not entirely sure what else the issue could be. If the suggestion above doesn't help and you'd like to submit a support ticket via the Members' Area here though I'll be glad to take a look at things for you.
    Durham, UK
    177
    Sorry, only just seen these replies. It's happened again, so I've submitted a ticket.
    Quote Originally Posted by angeljs View Post
    Let us know if it gets fixed - and how!
    Any luck there, angeljs?
    No?
    Have you guys tried making sure that the CMPS product and all plugins for the CMPS are enabled in your Admin CP?
    Just thought I'd pop in a few months later and see if there was any progress.
    This question was answered prior to your post.
    Quote Originally Posted by Morrus View Post
    I don't see how it would be possible to get that error if your $forumpath variable is correct and the CMPS product and plugins are all active. I don't know much else to suggest, but if you'd like to submit a support ticket via the Members' Area here then I'll be glad to take a look at things for you.
    Durham, UK
    177
    Okay, after all this time I've finally figured out what the problem is. I was working on another plugin, but when I came to save it, both CMPS and Dynamics went offline and gave errors on their pages. What had happened was that when I'd saved the plugin page, all of the vBadvanced plugins had become disabled, and they won't enable via the main page. I had to go to edit each one individually to set them as active. However, I'm still having problems as the init_startup (Dynamics) won't save because the PHP code box is blank!
  1. Call to undefined function: print_portal_output() on line 44
    By 3dc in forum Troubleshooting & Problems
    Last Post: 09-06-2010, 08:40 AM
  2. Fatal error: Call to undefined function print_portal_output()
    By Pirat3 in forum Troubleshooting & Problems
    Last Post: 09-02-2008, 11:56 AM
  3. Call to undefined function print_portal_output() error
    By eam in forum Troubleshooting & Problems
    Last Post: 08-13-2008, 05:14 PM
  4. Fatal error: Call to undefined function: print_portal_output()
    By kidswap in forum Troubleshooting & Problems
    Last Post: 01-03-2007, 06:02 PM
  5. Call to undefined function: print_portal_output
    By destro3m in forum Troubleshooting & Problems
    Last Post: 06-11-2006, 06:35 PM
