Thread: skins
    Jul 2005
    Default skins
    how to add new skin on vBadvanced___i have many skins for vbulletin
    Raleigh, NC
    1,614
    Default Re: skins
    It's a custom skin and isn't publicly available.
    My Blog
    GPS Discussion Forum
    *** Please do not contact me privately for help. Thanks. ***
    Default Re: skins
    Quote Originally Posted by kizi
    Kizi,
    Please clarify, are you asking how to use your existing skins with CMPS or something else? If you're asking about using your existing skins then you should be fine: CMPS will use the same skins/styles as vBulletin itself. Occassionally a style may need to be tweaked a bit but for the most part they usually work with no problems.
    Raleigh, NC
    1,614
    Default Re: skins
    Ah yes, Kevin. I think you nailed it. I mis-read/mis-understood.
    My Blog
    Default Re: skins
    I'm looking for some skins that will work with,
    * vbulletin 3.5.0
    * vBadvanced 2.0.0
    * vBadvanced gallery 1.0.1
    Kind of blue/purple colors that are 100%/fluid in width...
    Anything I need to look out for as far as installation and integration?
    Will any skin that works with vbulletin 3.5.0 work with the above?
    Mike
    Default Re: skins
    I just found this thread and it seems to answer all my questions...
    http://www.vbadvanced.com/forum/showthread.php?t=1538
    Mike
  1. Adding skins?
    By Milk Man in forum Troubleshooting / "How do I..." Questions
    Last Post: 04-06-2005, 06:39 AM
  2. different skins?
    By prodigy in forum Pre-Sale Questions
    Last Post: 03-08-2005, 06:39 PM
  3. add-on skins and vBa
    By disco4me in forum Troubleshooting / "How do I..." Questions
    Last Post: 03-04-2005, 05:40 PM
