vBadvanced Forums
Go Back   vBadvanced Forums > vBadvanced Products > vBadvanced CMPS > Add-On Modules & Modifications > Module & Modification Discussion & Requests
Reply
Thread Tools Display Modes
  #1
Old 01-07-2006, 06:15 PM
Atsuko Atsuko is offline
Junior Member
Default Hot to show members of certain usergroup
Maybe this is very basic thing, but I can not find the way to do.
I want to make a block showing members of certain usergroup.
How can I make it?
Please give the advice.
  #2
Old 01-11-2006, 04:10 PM
Chris-777 Chris-777 is offline
Member
Default Re: Hot to show members of certain usergroup
I'd like to know this as well.
  #3
Old 01-11-2006, 07:55 PM
PtP PtP is offline
Member
I have been trying to do this in some form or another for ages but seems to be an impossible task
  #4
Old 01-13-2006, 09:21 PM
Junior Member
It seems difficult thing...
Isn't there any solution?
  #5
Old 01-20-2006, 11:56 PM
1996 328ti's Avatar
1996 328ti 1996 328ti is offline
Senior Member
I was just searching for the same thing.
Edit: I'm going to look over here., It was something used in version 1.
__________________
...steven
www.318ti.org
forum.nccbmwcca.org
  #6
Old 01-22-2006, 09:41 PM
1996 328ti's Avatar
Senior Member
I'll pay $25 for someone to create such a module.
I need this for two usergroups.
__________________
...steven
www.318ti.org
forum.nccbmwcca.org
  #7
Old 01-23-2006, 09:50 PM
Junior Member
Hello!
I tried the instruction on the thread 1996 328ti wrote here.
Maybe because of the difference of version, my top page became blank....
So I agree with 1996 328ti 's ider to ask someone.
  #8
Old 02-08-2006, 02:07 AM
theczech theczech is offline
Member
Something like the module Quick Roster on our site? It shows all the Admins and members of a custom group called Team Member.
www.TeamMR.com
  #9
Old 02-15-2006, 10:09 PM
xan xan is offline
Junior Member
Cant you just do it in the permissions....vBACmPs Tab in ACP -> Edit Modules -> Select a module -> Scroll down
Viola your done.
  #10
Old 04-04-2007, 03:27 PM
randy17875 randy17875 is offline
Junior Member
Quote:
www.TeamMR.com
Checked out your site, looks great by the way, and would really like to see the way you did the Quick Roster module.
Randy
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Thread Thread Starter Forum Replies Last Post
Members of usergroup listed in a module joeychgo Add-On Modules & Modifications 37 06-24-2005 06:21 PM
Show a members username on a module? ERuiz Troubleshooting / "How do I..." Questions 1 02-26-2005 01:38 PM
Show richest members on CMPS ? LoOnEyToOnZ Add-On Modules & Modifications 11 08-11-2004 07:48 PM
Forums Powered by vBulletin, Copyright ©2000-2009, Jelsoft Enterprises Ltd.
Please note that vBadvanced is in no way affiliated with Jelsoft Enterprises Ltd, nor will Jelsoft be able to provide any support for our products.
