vBadvanced Forums
Go Back   vBadvanced Forums > vBadvanced Products > vBadvanced CMPS > vBa CMPS v3.0 Support > Troubleshooting & Problems
Reply
Thread Tools Display Modes
  #1
Old 05-21-2009, 10:40 AM
brathamike brathamike is offline
Member
Default 3.2.2 drag and drop?
Hello i installed the new upgrade but i dont see the drag and drop? How does this function actually works? Do i need to enable this function in the admin?
please help
thanks
  #2
Old 05-21-2009, 10:45 AM
HenrikHansen HenrikHansen is offline
Senior Member
I have not upgraded, but Brian says in the announcement forum that the setting has to be enabled.
'Allow Page Customization' under the 'Main Options' section
To see it work here, look at the top to the right at www.vbadvanced.com (customize this page)
  #3
Old 05-21-2009, 10:50 AM
Member
what announcement forum are you speak about? and the customize page is not on my screen. I dont see it. That link you gave me is on vb website i do not see that link on my website
  #4
Old 05-21-2009, 10:52 AM
Senior Member
This announcement
http://www.vbadvanced.com/forum/showthread.php?t=35247
Go the www.vbadvanced.com to see it work. It does not work on the forum sites
  #5
Old 05-21-2009, 10:56 AM
Member
well that was kind of a waist of a update since now i need to buy vBadvanced Dynamics v1.2.0 just to get the drag and drop feature..So this really
is not a update for vBadvanced CMPS
  #6
Old 05-21-2009, 11:05 AM
Senior Member
Are you sure you do not have the setting 'Allow Page Customization' under the 'Main Options' section in you CMPS admincp menu, even though you do not have Dynamics 1.2.0?
  #7
Old 05-21-2009, 11:23 AM
Member
The only way for me to get that option that you are speaking about is for me to BUY dynamics. To answer your question i do not have that function to enable it since i do not have dynamics
  #8
Old 05-21-2009, 11:27 AM
scottct1 scottct1 is offline
Junior Member
I do not have Dynamics but due see "allow page customization" in the page settings in CMPS.
When I turn it on I can click on Customize This Page, which then puts the page in edit mode, however I can not drop and drag the boxes, when I try the boxes just highlight.
When I try it here on vbadvanced.com the drag and drop features work great.
I turned off the "allow page customization" feature for now.
  #9
Old 05-21-2009, 11:33 AM
Member
Please close thread im no logger subcribed to thread i do not have this..."allow page customization" in the CMPS
thanks
close forum
  #10
Old 05-21-2009, 04:14 PM
Brian's Avatar
Brian Brian is offline
Administrator
Nowhere does it say that you need vBa Dynamics to take advantage of the new drag & drop features in the CMPS. Drag & drop features have been added to both products. All you need to activate it on the CMPS is to upgrade and then edit any CMPS pages through the Admin CP to enable the new 'Allow Page Customization' setting.
  #11
Old 05-21-2009, 08:20 PM
jhj8864 jhj8864 is offline
Junior Member
I just installed, and as Brian states, I don't have vBa Dynamics and the drag and drop feature is working perfectly. Love it
  #12
Old 05-21-2009, 11:42 PM
PoltergeistII PoltergeistII is offline
Junior Member
Not sure if I have the save problem as brathamike but after upgrading I don't have the option "Allow Page Customization" on any of my settings pages for vBadvance CMPS. Everything else seems fine and the upgrade seemed to go with no problems reported.
  #13
Old 05-21-2009, 11:48 PM
Junior Member
Nevermind found the problem was in the instructions saying to go to Main Options when it is: admincp--> edit pages---> go homepage --> Allow Page Customization you must choose ( yes )
  #14
Old 05-22-2009, 12:30 AM
GateKeper GateKeper is offline
Member
just did the upgrade, and all is fine....
Thanks for the continued support....
GK
  #15
Old 05-22-2009, 11:18 AM
Brian's Avatar
Administrator
Quote:
Not sure what instructions you're reading, but it does say you have to edit the CMPS page in the Announcement.
Quote:
When adding or editing a CMPS page, you will now see a new option called 'Allow Page Customization' under the 'Main Options' section.
  #16
Old 05-22-2009, 11:45 AM
Junior Member
Quote:
I did that.
Then when I click on the Customize This Page on my site all the boxes have the ----'s going around it, but when I click on a box to drag and drop it just highlights the text on the screen and does not move the boxes.
Here (on your site) I am able to drag the boxes with no problem.
  #17
Old 05-22-2009, 12:03 PM
Brian's Avatar
Administrator
Are you receiving any javascript errors on the page?
  #18
Old 05-22-2009, 12:32 PM
Member
yep I found it too.. had to take a break from my computer to clear my head
LOL
  #19
Old 05-22-2009, 12:36 PM
Member
Great work brian
  #20
Old 05-22-2009, 01:13 PM
xTerMn8R xTerMn8R is offline
Member
Question
I have a similar problem to the Dragging Modules in the adminCP. The wierd thing is that when I first installed it allowed me to remove a module (drag it to the inactive Modules) from my Home page. Now I do have the "Customize this Page" link on my home page and it works fine for users to modify the Home Page display, BUT I cant add or remove any modules in the admincp, it just highlights them now when I click on them... This is not good and Now I have no idea on how to add back my modules to my home page, I removed in testing the Upgrade.
I'm using IE8, vb3.8.2 and cmps 3.2
Super Skunk Racing
Thank you,
xT
Hmmmmmmmm wierd thing, when I went back in the adminCP and hit the "SAVE" button in the inactive modules area it began to work again...I would have thought that when you click the Save on the bottom of the page after making changes it would Save everything, Ya shouldn't have to click Save twice in 2 different spots...
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Thread Thread Starter Forum Replies Last Post
after upgrade DYN 1.2.0 can't see the drag & drop option troppodel Troubleshooting & Problems 2 05-20-2009 11:33 AM
How to make Vbadvanced moduls drag & drop orkyn "How Do I..." Questions 1 04-08-2009 12:19 PM
Quick Links Drop Down - Add a drop down to your column. jackf Add-On Modules (version 3.x & 2.x) 4 01-19-2009 07:45 PM
Drag And Drop ManagerJosh Feedback & Suggestions 3 08-09-2007 11:07 PM
Forums Powered by vBulletin, Copyright ©2000-2009, Jelsoft Enterprises Ltd.
Please note that vBadvanced is in no way affiliated with Jelsoft Enterprises Ltd, nor will Jelsoft be able to provide any support for our products.
