vBadvanced Forums
Go Back   vBadvanced Forums > vBadvanced Products > vBadvanced Links Directory > vBa Links Directory v1.0 Support > Modifications
Reply
Thread Tools Display Modes
  #1
Old 12-04-2004, 06:11 PM
Lionel Lionel is offline
Senior Member
Default [Request]importing links
I downloaded this free script
http://www.onlinemarketingtoday.com/...nk-management/
can someone use the code in there to import whole categories and links from the DMOZ and adapt it with vblinks? That would give us a huge headstart.
  #2
Old 12-24-2004, 12:28 PM
interfx interfx is offline
Senior Member
Default Re: [Request]importing links
I used to use WSNLinks, and it had a way to imprt a DMOZ directory using the output from http://ostermiller.org/tulipchain/...
It worked well, but you had to choose a smaller directory not to overload it...
Has anyone created a script to import any format of links into VBa Links?
InterFX
__________________
InterFX
<br><br>
my Clients using VBa:
ChristianMom.com | BrassReview.com | TrumpetForum.com
  #3
Old 12-24-2004, 12:34 PM
Senior Member
One more tool that I used to use was this one (import.php)...
This worked by typing in a URL, then it would go through the html page, and strip the links and directly import them into WSNLinks...
I think could work here on VBa Links - but would need modification to put results into the correct database tables...
Anyone feel up to it?
InterFX
__________________
InterFX
<br><br>
  #4
Old 03-14-2005, 02:07 PM
oldengine oldengine is offline
Member
I keep searching the key words IMPORT LINKS and nothing new is happening. It would sure be nice to do something easier than cut and paste links for a day at a time.
  #5
Old 03-14-2005, 04:02 PM
Senior Member
I too, am desperate for this.
  #6
Old 03-15-2005, 11:36 AM
Polo's Avatar
Polo Polo is offline
Senior Member
I'm interested in this too
__________________
God180.com <---------------------My heavily modified vBulletin board
  #7
Old 03-15-2005, 01:03 PM
Senior Member
Fetching a category should not be too hard. Let's say you have one screen with links category, title, url and description, and another field for dmoz category. Then you click on submit and it imports those dmoz links of that category you specified into links category. For someone who knows, it should be less than 5 minutes. That is bad for those of us who don't know have to suffer.
  #8
Old 03-15-2005, 01:12 PM
Polo's Avatar
Senior Member
maybe someone can write a tutorial or something...
__________________
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Thread Thread Starter Forum Replies Last Post
[REQ] - Top 10 or Latest Links side block. ricoche Modifications 1 01-27-2005 09:36 AM
vBadvanced Links Directory RC3 Now Available! Brian Announcements 37 01-24-2005 05:58 AM
vB, vBa, links integration Giray "How Do I..." Questions 9 09-24-2004 12:13 PM
Replying to Links ricoche "How Do I..." Questions 3 09-15-2004 12:13 PM
Top X Links Block... Shon Feedback & Suggestions 3 07-23-2004 12:54 PM
Forums Powered by vBulletin, Copyright ©2000-2009, Jelsoft Enterprises Ltd.
Please note that vBadvanced is in no way affiliated with Jelsoft Enterprises Ltd, nor will Jelsoft be able to provide any support for our products.
